I tried uninstalling and re installing, i checked all settings as per your website. On your website when checking to see if flash is installed it says not. I'm running windows vista 32 bit and all updates are current. On you tube it says you need to upgrade your flash. And no amount of re installing works.
What browser?
Internet explorer but I've tried Firefox as well with the same results.
Sent from my iPhone
Is Shockwave Flash enabled in both Internet Explorer and Firefox?
What files do you have in C:\Windows\system32\Macromed\Flash ?
The enable and disable is greyed out. Even after reinstalling I can't enable it.
Sent from my iPhone
Not sure what this means; can you try a clean install as described in http://forums.adobe.com/thread/928315
I've done that as well makes no difference.
Sent from my iPhone
Hey guys, I am having the same problem with my Flash player! 2 days ago, I was playing Candy crush on FB and everything was fine! Last night I logged in and tried to play and it said I needed to upgrade my Flash Player! I looked in my control panel (add/remove programs) and Adobe Flash player 12 active X is listed and well as the plugin and they are both enabled in IE and FireFox! Went to Adobe.com to try to re-install and as I click on Install now, it just takes me to the Adobe.com homepage! I am running Windows XP. I have, of course, noticed I can not watch alot of my videos, etc. I did the Adobe Flash player CHECK and it says that it is not installed at all.... I of course, did nothing to the computer, ie.. install new programs or delete or anything of the sort, it is just so weird, it just stopped running all together! Help Please!!!
