1 Reply Latest reply: Feb 24, 2014 9:41 PM by tman69 RSS
    Spot color swatches in AICS6 and AICC do not match color in design
    garyscott19 Community Member
      Hello,
      Some of the lighter, saturated colors in the PANTONE+ swatches library appear to be a different color in the swatch list than they are when applied to a design.
      Please, see below for screen shots.
      i can duplicate this situation on calibrated NEC MultiSync monitors and uncalibrated laptops. We are running on Mac OS X.8x and above.
      Designers are complaining about not being able to pick a color from the Swatch Library in AICS6 or AICC.
      InDesignCC does not seem to have the same issue.
      Is this a color managment issue?
      Does anyone have any ideas?
      Thanks for your help.
      Gary Scott
      Technology Support
      Landor Associates
      Screen Shot 2014-02-24 at 4.24.21 PM.pngScreen Shot 2014-02-24 at 4.24.33 PM.png
        • 1. Re: Spot color swatches in AICS6 and AICC do not match color in design
          tman69 Community Member
          pantone 361 is pantone 361 no matter how it appears on screen--that said--creating a design and 'then' appying a color can have 'different' results depending on what 'effects' were applied to the design--any transparent effects can cause a color shift--and--in my experience--many designers don't realise that when they use an 'effect' on an object (drop shadow, multiply, etc) and then create another object--the effect is also being applied (27 years in prepress verifies this)
          as far as your screen shots are concerned--they appear identical on my monitor.
          try this test with one of your designers--have them create an illustrator document with a rectangle filled with a spot color--save it as an .ai file---then have them place that file in Indesign and create a rectangle there--load the same color in the indesign pallette  and draw/fill a rectangle before placing the .ai file--then see if they match
