1. Re: Remove / Disable the signature requirement on a Form
a C student Feb 26, 2014 7:11 AM (in response to Robert222)Hi Robert,
It sounds like you are talking about the prompt in Acrobat Reader that advises users to "Click "Sign" to fill out and sign this form. When you are done, you can save a copy by clicking "Done Signing"." This prompt confuses and annoys a lot of people. You can make it go away by saving your form as Reader Extended. In Acrobat, Save as Other > Reader Extended PDF > Enable More Tools (includes form fill-in & save). Exact terminology varies depending on your version of Acrobat. Be sure to save a copy of the non-extended version of the form for future editing.
If you have just a few known users you could also ask them to upgrade to Reader XI, I understand it does not display the annoying prompt. Or you could ask them to ignore the prompt, which they can do - it does not effect the use of the form other than causing confusion.
Hope this helps.
a 'C' student
2. Re: Remove / Disable the signature requirement on a Form
Robert222 Feb 26, 2014 12:52 PM (in response to a C student)Thank you very much! That worked.
You're at least a 'B-' student now
3. Re: Remove / Disable the signature requirement on a Form
cree2me Nov 7, 2014 12:49 PM (in response to a C student)Thanks C Student, I was having the same problem with my forms.
