In the Table of Contents Pod, I can right-click on a topic/page and select "Create Book from Page." When I do so, the resulting "book" is not selectable. I have to bring in the page again and place it below the "Book" title. This can't be right! What am I doing wrong, or what should I be doing?
You're doing everything right. When you use this feature, RoboHelp
creates a book without a topic linked to it and leaves the topic. You
must manually associate the topic with the book and remove the topic.
You can submit a change request for this behaviour using the following
link:https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&product=12
The more people wish for a feature, the more likely it is that Adobe
will implement it.
Kind regards,
Willam
Here's what I found as to how to associate a topic with the book:
You’ll have to create a topic to associate with that book. Here’s one way to do that:
This places that topic in the level under that book. Now you just need to associate that topic with that book (so that when you click on the book, this topic displays).
To see if your topic is now associated with your book:
But... (see the second bullet above) After I click "page" I think it wants me to select a page from the list of topics. When I select the proper page and continue through the process, the topic page is still below the Book title and the Book still isn't clickable!
It appears I'm doing something wrong on the association part, but I don't know what!
Solved it!
Right-click on the Book. Go to Properties. Make sure Book with Link is checked (check it if not). Scroll through the list of topics until you find the one with the same name. Click OK. Then delete the topic entry.
Here's where the trap was....... The Book heading still "doesn't work" in the Table of Contents pod, but when the chm file is created it works as expected!
Whew!
