I am using RoboHelp HTML version 10. I have created a master project containing about 40 individual projects. Of these I have 8 which are showing the breadcrumb line twice and one which is showing it 3 times on each page. Why are these showing multiple times and how do I fix it?
I have also noticed that in each project which is showing multiple lines, it is also showing the name of the project multiple times -
e.g. Home > Doc1 > Doc1 > Introduction
Sharon
Hi there
If you are talking about a Master/Slave or Parent/Child setup, perhaps Peter will know more about that when he wakes up here in a few hours.
But one thing I know for certain is that you will see repeated rows if you have defined a Master Page with breadcrumbs in it as well as having breadcrumbs enabled in the Single Source Layout properties. If that's the case, you typically need to turn them off in the Single Source Layout recipe.
Cheers... Rick
I don't think this is merge related and suspect Rick's suggestion is the problem.
What do you see if you open the child project output directly?
Thanks for your help. When I looked at the child projects they were displaying one line so I remerged them into the parent project and the issue is resolved.
