Im using Presenter 8 and when i am creating a quiz from scratch, i am able to use the quiz manager to select 'if passing grade, go to slide xyz' thats fine, however...
after creating a few questions, as you normally would, i go to amend the 'if passing, go to slide xyz' (simply because the amount of question lside has now changed the slide i want it to go to) when i do it reverts straight to 'go to next slide' im not able to select go to slide xyz anymore!
i have retraced my steps and i cannot put my finger on what i am doing to stop it from working!
can anyone shed any light?...
Hi
do you have already found an answer to your question? I am currently facing exactly the same issue.
Stefan
What version of Presenter 8?
I am using Presenter 9.0.2
Hello
Its version 8.0.1
Thank you
Hi
I dont see any issue in the pass or fail option settings as you mention. Probably there is a certain steps to reproduce it or i didn't get it correctly.
But one thing what i got is that once you set "Go to Slide" option, no need to modify it again. The correct link for the same slide will be updated automatically.
Can you please share a screenshot of the pass or fail option dialog that will help me to undestand the issue ?
Also please share the reroducible steps pointwise.
Sunil
Adobe presenter Engg Team
Thanks for your support on this.
In the meanwhile I have added a second quiz to the presentation and transferred the content from the first one to that second quiz. With the second quiz the “go to slide” option works.
Thanks again
Best regards
Stefan
