Every time I log in Robohelp 6.0 as an administrator I get the following message : " Unable to register hhctrl.ocx, itircl.dll, itss.dll" How can I fix this?
That doesn’t sound like a WebHelp issue – it sounds more like a CHM thing – have you got the MS HTML Workshop installed?
no idea, where can I check to see if I have it installed?
Hi there
Questions here. You state RoboHelp 6? Pretty long in the tooth and I'm not sure it will even run successfully on a newer OS.
What is your OS? The fact you state you are running as an administrator would seem to suggest Vista, 7 or 8 of Windows.
Has RoboHelp ever run successfully on this machine and the errors are new?
The answers to the questions above will determine what is advised next.
Cheers... Rick
I have Windows 7 and no it has never run succesfully on this machine, always that error.
I would suspect that it has to be run in either XP mode or in an XP virtual machine.
In other words, I would need to upgrade
No, not necessarily – you can try running in XP mode by configuring the shortcut; running the free XP VM in Win7 depends on your version of Win7 (Home, Pro, etc.)
How do I set that up? I have Windows 7 Enterprise. I use Robohelp at work.
Just found it, set it up and no longer receiving the error! Thank you!!!
Start here - http://windows.microsoft.com/en-CA/windows7/install-and-use-windows-xp-mode-in-windows-7
