1. Re: Indesign CC PDF Mutli- Page Placing
Ellis home Feb 27, 2014 5:31 PM (in response to Drew_F)File/Place and hold Shift key down. That should place the whole document at once.
2. Re: Indesign CC PDF Mutli- Page Placing
Peter Spier Feb 27, 2014 5:35 PM (in response to Drew_F)For a PDF I'd suggest this script: InDesignSecrets » Blog Archive » Zanelli Releases MultiPageImporter for Importing both PDF and INDD Files
3. Re: Indesign CC PDF Mutli- Page Placing
Drew_F Feb 27, 2014 5:40 PM (in response to Ellis home)Not sure why it only places one page at a time?? when I use the shift key
4. Re: Indesign CC PDF Mutli- Page Placing
Drew_F Feb 27, 2014 5:41 PM (in response to Peter Spier)@Peter Spier, I tried the Znelli release but I couldnt get it to work in CC. I may not be adding it to the right file
Any ideas
5. Re: Indesign CC PDF Mutli- Page Placing
Peter Spier Feb 27, 2014 5:49 PM (in response to Drew_F)I haven't tried it in CC yet, but it works in CS6, so it should run if you put it in a subfolder of the scripts panel folder named "Version 8.0 Scripts" (without the quotes, but case sensitive).
6. Re: Indesign CC PDF Mutli- Page Placing
Drew_F Feb 27, 2014 6:00 PM (in response to Peter Spier)Could I ask where you place the sub file
I though it would be C:/Program Files (x86)/Adobe/AdobeInDesignCC/Scripts/ScriptsPanel/Samples
But I can't get it to run?
7. Re: Indesign CC PDF Mutli- Page Placing
Ellis home Feb 27, 2014 6:07 PM (in response to Drew_F)In Indesign you need to go to Window/Utilities/Scripts. Right click on User/Reveal in Explorer and drag the file to Scripts Panel.
8. Re: Indesign CC PDF Mutli- Page Placing
Drew_F Feb 27, 2014 6:31 PM (in response to Ellis home)Thanks Ellis
I have done that, could you help me with making it work.
I have got to file/ PLace/ etc.. placed the PDF on the page but it only carries in the one page even when I have used the shift key or clicked all pages. The Windo from the new script does not open.
How do I open the new script window to tell it to place all pages.
I am really really thank full to everyone. I am only new at this and I need to get this finished or my boss will not be happy with me.
9. Re: Indesign CC PDF Mutli- Page Placing
Drew_F Feb 27, 2014 6:34 PM (in response to Drew_F)I did it everyone
It works so well
THANK YOU so much
10. Re: Indesign CC PDF Mutli- Page Placing
Ellis home Feb 27, 2014 7:42 PM (in response to Drew_F)Glad you sorted it out. You double click the script and take it from there. By the way the File/Place holding down Shift works for placing word docs. For multi paged PDF's you use the script as Peter correctly pointed out.
