Issue: Incorrect location of pop-up windows.
Cause: The possible reason of this issue could be a pop-up window or an image-pop-up window and "Drop-down Hot Spot" or "Expanding Hot Spot" text exist in a topic.
RH version: I faced the issue in RH v8 with patch 2. (Not sure about other versions!)
Output: CHM, WebHelp
Solution: As a solution to the pop-up windows not showing at correct location, a script file was provided by Praful Jain (see his post on the above forum at Post#17 for more details.)
I had the same issue with the pop-up windows in few topics while in other topics it worked well. After running the said script file, the issue did not resolve for me and pop-ups were showing up at top left corner of the Help window.
I found that the script rightly resolves the issue of normal pop-up windows but it does not fix the image-map pop-up windows issue, and I was using image-map pop-ups in my window.
I did some modification to the script and executed the modified script in my project. I got my issue of image-map pop-ups incorrect placement fixed.
I have uploaded the modified version of the script file @ https://workspaces.acrobat.com/?d=L77ZP59R4Y6rTo9lG8Q4DA
Hope this script helps to all those who are facing the same problem in their projects. It worked very well for me, but I would advise all to take backup of their project before running this script.
Follow the below steps to executing the script file–
A special thanks to Eileen for providing help. 🙂
~Vimal
Thank you for sharing that Vimal.
Is this script file still available?
I am having the same pop-up location problem as mentioned and would like to try the script on it. Unfortunately, when I click on the link above, I am redirected to a blank screen. I have checked with my company Support and they say it isn't due to our firewall.
regards,
Christina
It is because the host site got reorganised. I have put out a request for the new link.
Thank you.
cheers,
Christina
Correction. I assumed the link did not work because the site got organised. In fact the link is still working just fine, I tried it. Something is blocking it for you so go back to IT or try the link from home.
I got back to Support and they did their voodoo and downloaded the script for me. Have run it and my problem is now fixed.
A big thank you to both of you. 🙂
cheers,
Christina
Since workspaces.acrobat.com is retiring soon, placing the file here itself:
* $$FileName Popup Placement Fixer.jsx
* $$Description Sample ExtendScript file Fixes the popup placement issues in CHM output of RoboHelp 8
* Author Praful Jain
* Copyright (c) 2009 Adobe Systems Incorporated. All Rights Reserved.
* Modified by: Vimal Chhutani (22.02.2013) to include Image Map pop-window placement
var topicmgr;
main();
function main()
msg('Starting The Fixing Process');
topicmgr = RoboHelp.project.TopicManager;
FixAllPopups();
msg('Done with Fixing');
function FixAllPopups()
if(topicmgr.count>0)
var topic = topicmgr.item(1);
while(typeof(topic)!='undefined')
FixPopupInTopic(topic.path);
topic = topic.next;
function FixPopupInTopic(filepath)
msg('Parsing Topic '+filepath);
//we will create al popup ID with name PopupID+count
var stringToSearch = 'javascript:bsscpopup(';
var tokenmgr = RoboHelp.getTokenManager(filepath);
var bSave = false;
if(typeof(tokenmgr)!='undefined')
if(tokenmgr.count>0)
var token = tokenmgr.item(1);
while(typeof(token)!='undefined')
//check if it is text or not
if(token.tokenType == RoboHelp.TokenType.TOKENTAG) // && token.tagType == RoboHelp.TagType.TAGANCHOR)
//we need to find the href attribute and see if it contains javascript:BSSCPopup(
var hrefString = token.getAttribute('href');
if(typeof(hrefString)==='string' && hrefString.length>0)
var orghrefString = hrefString;
hrefString = hrefString.toLowerCase();
if(hrefString.indexOf(stringToSearch)!=-1)
//this is the token with popup link, we need to find the onclick attribute now
var onClickAttribute = token.getAttribute('onclick');
if(typeof(onClickAttribute)=='undefined' || onClickAttribute.length==0)
msg('Found buggy popup Links Fixing now');
//we found a popup with issue
//fix the popup now
//we need to set the href as javascript:void(0);
token.setAttribute('href','javascript:void(0);');
//now add the onMouseover attribute
token.setAttribute('onmouseover','if (parseInt(navigator.appVersion) >= 4 && typeof(BSPSPopupOnMouseOver) == \'function\') BSPSPopupOnMouseOver(event);');
//set onclick attribute now
orghrefString +=';return false;';
token.setAttribute('onclick',orghrefString);
bSave = true;
token = token.next;
else
alert('there is some error in getting the token manager');
if(bSave)
msg('saving file '+filepath);
tokenmgr.save();
function msg(szString)
RoboHelp.project.outputMessage (szString);
RoboHelp.project.outputMessage ('\n');
~Amit Agarwal
