I have IE 11.0.9600.16518 and am trying to get flashplayer to function, because many sites do not display content and some links on various sights do not work. Because the adobe flashplayer site does not display content in IE, I used Safari to go to the site and download the necessary files. I have attempted a clean install of flashplayer by running the uninstall utility from the adobe site. I looked for the Macromed folder in Windows\SysWOW64 and it only contained a FlashInstall notepad file. I restarted the PC, then downloaded the current flashplayer 12 installer, then ran it. It looked like it installed, I think, but the adobe web screen remained on step 2 of 3 and I could see now way to advance to step 3. When I opened IE and attempted to manage add-ons, Adobe did not show in the window with Toolbars and Extensions selected (though many other add-ons did show). The Macromed folder in SysWOW64 still does not contain any files except the Notepad file. I have done this process several times to make sure I didn't miss something. When I try to install flashplayer a second time, the system tells me that "only a single instance of this program can run." So it appears the system thinks flashplayer is installed or installing, but I can't find it and IE can't see it. Please help.
I forgot to include this: Windows 7 ultimate SP1, 64-bit.
Try running these installers
Flash Player for ActiveX (Internet Explorer)
Flash Player Plug-in (All other browsers)
If there is still nothing in the Flash Player install folders, can you post the contents of that FlashInstall.log file (from both C:\Windows\System32\Macromed\Flash & C:\Windows\Syswow64\Macromed\Flash).
Thanks, Pat. These are the actions that I took and the results:
1. Ran Adobe Flash Uninstaller
2. Rebooted
3. Cleaned out all four folders per the "clean install" instructions
4. Installed the two Flash Player executables from the links you provided (I installed both because I have IE and Safari browsers installed)
5. Checked the System32 and SysWOW64 folders and they contained exe files and installation logs which I will attach
6. Opened up IE 10 (I had previously reverted from IE 11 based on other comments in this forum), but then realized that the new flash player might only be for IE 11
7. Installed IE 11 through windows update
8. Opened IE 11, and Manage Add-Ons now shows Adobe Shockwave Flash Object, enabled (32-bit and 64-bit).
9. Tried YouTube -- video windows remain black and the "loading" wheel spins continuously; tried other sites and seemed to have similar results
10. Opened Safari (ver 5.1.7), ensured Java was enabled, and had similar results
11. I'm interpreting my problems as being due to Flash Player, though I could be incorrect. For example, when trying to log in to this forum discussion, IE 11 took me to the sign-in page, displayed the "Joint the Adobe Community" header, and showed a continuos spinning wheel. Safari produced similar results, except it let me enter email address and password before going into the spinning wheel mode. When I used Chrome to sign-in, all worked fine (I'm assuming because Chrome comes with flash already loaded.)
12. Below are the two installation log files.
C:\Windows\System32\Macromed\Flash\FlashInstall.log
=O====== M/12.0.0.70 2014-03-01+19-45-41.194 ========
0000 00000010 "C:\Users\Mark\AppData\Local\Temp\{F1269D8C-E5EC-4F58-96A9-52FE88EF9F36}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0003
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_12_0_0_70.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
=X====== M/12.0.0.70 2014-03-01+19-45-43.567 ========
=O====== M/12.0.0.70 2014-03-01+19-46-48.035 ========
0000 00000010 "C:\Users\Mark\AppData\Local\Temp\{EB75B0DF-D944-4E78-AD17-315A21301096}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_12_0_0_70.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_Plugin.exe
0013 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0014 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
=X====== M/12.0.0.70 2014-03-01+19-46-50.120 ========
C:\Windows\SysWOW64\Macromed\Flash\FlashInstall.log
=O====== M/12.0.0.70 2014-03-01+19-45-33.448 ========
0000 00000010 "C:\Users\Mark\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\XSTBBMZJ\install_flash_player_ax.exe"
0001
0002
0003
0004
0005
0006
0007 00000011 1
0008 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009
0010 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_70.ocx
0011 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
0012 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
0013 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0015 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/12.0.0.70 2014-03-01+19-45-58.662 ========
=O====== M/12.0.0.70 2014-03-01+19-46-22.767 ========
0000 00000010 "C:\Users\Mark\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\MJUNO48D\install_flash_player.exe"
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026 00000011 1
0027 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0028
0029
0030
0031
0032
0033
0034
0035
0036 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_70.dll
0037 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_Plugin.exe
0038 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0039 00000017 C:\Windows\SysWOW64\Macromed\Flash
0040 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe
0041 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0042
0043
0044 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0045
=X====== M/12.0.0.70 2014-03-01+19-47-26.767 ========
I have the exact same problem! I done everything I can thing of to install Adobe Flash Player 12 and have it recognize by either Windows 7 or IE 11.
I unloaded it using Adobe's uninstall app and shut off my computer.
I start it back up again and then shut if off again for the second time.
I downloaded and run Flash Player 12.
try it and on an video - ask again for upgrading. For fun I upgraded it 6 times in a row and still it said to upgrade needed.
Installed Flash Player with Xactive
Shut down Windows 7
Start it up again - go to an video and still ask to upgrade to the latest Flash Player!
Uninstalled IE 11 and reboot computer.
Go to IE10
Use IE10 to view video - same thing - need latest Flash. Upgrade latest Flash again and then shut off computer.
Start it back up and go to video and ask to upgrade to latest Flash before it can show video.
I am so frustrated.
Why can't Windows 7 and IE recognized the installation of Flash Player 12?
Anyone?
Here is my log ->c:\windows\syswow64\macromed\flash\flashinstall.log:
=O====== M/11.5.502.110 2012-12-01+10-36-08.040 ========
0000
0001 00000010 "C:\ProgramData\Adobe\AIH.ef18c66ee4c55e42825082903d380d0668d9a593\install_flash_player_ax.exe" -install -iv 8 -au 0
0002
0003
0004
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00000011 1
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_110.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_110_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_110_ActiveX.dll
0011 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0012 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0014 00000012
=X====== M/11.5.502.110 2012-12-01+10-36-15.828 ========
2012-12-7+8-34-0.218 [error] 1223 1056
2012-12-12+16-52-36.165 [error] 1214 12007
2012-12-12+16-52-36.165 [error] 1234 0
2012-12-14+3-34-19.590 [error] 1226 1062
=O====== M/11.5.502.135 2012-12-14+03-34-08.873 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002 00000011 1
0003
0004 00000018
0005
0006 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_135.ocx
0007 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe
0008 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.dll
0009 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.5.502.135 2012-12-14+03-34-20.807 ========
2013-1-7+6-34-0.213 [error] 1223 1056
2013-1-8+20-34-17.468 [error] 1226 1062
=O====== M/11.5.502.146 2013-01-08+20-34-08.919 ========
0002 00000011 1
0003
0004 00000018
0005
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_146.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
0010 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0011 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012
0013
0014 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0015
0016
0017
0018 00000012
=X====== M/11.5.502.146 2013-01-08+20-34-18.700 ========
2013-1-13+10-34-0.219 [error] 1223 1056
=O====== M/11.5.502.146 2013-01-21+01-48-30.249 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Temp\{13BAEE5F-C349-4004-823D-B39CF2876DB3}\InstallFlashPlayer.exe" -iv 6
0002 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_146.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
0006 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0007 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0008
0009
0010 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0011
0012
0013
0014 00000012
=X====== M/11.5.502.146 2013-01-21+01-50-09.138 ========
=O====== M/11.5.502.146 2013-01-21+01-48-21.565 ========
0000 00000010 C:\Users\Harry\AppData\Local\Temp\IDC2.tmp\FP_AX_CAB_INSTALLER64.exe
0001 00000011 1
=X====== M/11.5.502.146 2013-01-21+01-50-09.153 ========
2013-2-8+0-34-19.840 [error] 1226 1062
=O====== M/11.5.502.149 2013-02-08+00-34-08.514 ========
0002 00000011 1
0003
0004 00000018
0005
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_5_502_149.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.5.502.149 2013-02-08+00-34-21.103 ========
=O====== M/11.6.602.168 2013-02-14+07-42-13.770 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RMDLOHWN\install_flash_player_ax.exe"
0001 00000011 1
0002 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003
0004 00000018
0005
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_168.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.dll
0012
0013
0015
0016
0017
=X====== M/11.6.602.168 2013-02-14+07-42-34.130 ========
2013-3-3+9-34-19.500 [error] 1226 1062
=O====== M/11.6.602.171 2013-03-03+09-34-09.642 ========
0001 00000011 1
0003
0004 00000018
0005
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_171.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_171_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_171_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.6.602.171 2013-03-03+09-34-20.733 ========
=O====== M/11.6.602.171 2013-03-13+06-34-09.629 ========
0001
=X====== M/11.6.602.171 2013-03-13+06-34-10.269 ========
2013-3-13+16-34-27.761 [error] 1226 1062
=O====== M/11.6.602.180 2013-03-13+16-34-16.826 ========
0001 00000011 1
0003
0004 00000018
0005
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_6_602_180.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.6.602.180 2013-03-13+16-34-28.994 ========
=O====== M/11.7.700.169 2013-04-22+19-51-02.011 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.b834c323a3556eb42cc7c50cbd7c1d4bf87c6652\install_flash_player_ax.exe" -install -iv 10
0001 00000011 1
0003
0004 00000018
0005
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.7.700.169 2013-04-22+19-51-08.021 ========
=O====== M/11.7.700.169 2013-04-23+09-04-47.687 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Temp\{89626395-05EE-470B-8183-3311A0B662E2}\InstallFlashPlayer.exe" -iv 6
0001 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_7_700_169.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
=X====== M/11.7.700.169 2013-04-23+09-05-54.779 ========
=O====== M/11.7.700.169 2013-04-23+09-04-38.842 ========
0001 00000011 1
=X====== M/11.7.700.169 2013-04-23+09-05-54.795 ========
=O====== M/11.7.700.169 2013-04-24+16-43-15.636 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Temp\{609113C9-2B98-4047-AEB0-2B8506F908FE}\InstallFlashPlayer.exe" -iv 6
0001 00000011 1
0008
0009
0011
0012
0013
0014 00000012
=X====== M/11.7.700.169 2013-04-24+16-43-42.344 ========
=O====== M/11.7.700.169 2013-04-24+16-43-07.010 ========
0001 00000011 1
=X====== M/11.7.700.169 2013-04-24+16-43-42.375 ========
2013-5-15+9-34-15.215 [error] 1226 1062
=O====== M/11.7.700.202 2013-05-15+09-34-06.541 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 11
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{A0707BCB-DA08-42A9-B57A-D1D8EB573F81}\Flash32_11_7_700_202.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
0012 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0013 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014
0015
0016 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0017
0018
0019
0020 00000012
=X====== M/11.7.700.202 2013-05-15+09-34-16.447 ========
2013-6-12+4-34-13.930 [error] 1226 1062
=O====== M/11.7.700.224 2013-06-12+04-34-07.114 ========
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{94969095-E2C3-4DDE-AFB9-8D9799B2316D}\Flash32_11_7_700_224.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/11.7.700.224 2013-06-12+04-34-15.146 ========
=O====== M/11.8.800.94 2013-07-10+16-27-35.797 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.4cf9c30282e2ed2e769f27b439a7ede692e9f923\install_flash_player_ax.exe" -install -iv 8
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0013
0014
0016
0017
0018
0019 00000012
=X====== M/11.8.800.94 2013-07-10+16-27-42.656 ========
2013-9-4+9-34-0.207 [error] 1223 1056
2013-9-11+4-34-17.536 [error] 1226 1062
=O====== M/11.8.800.168 2013-09-11+04-34-05.430 ========
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{BA9F5688-C687-4EC1-8738-83EF45EE2A7F}\Flash32_11_8_800_168.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/11.8.800.168 2013-09-11+04-34-18.815 ========
2013-9-14+11-34-13.460 [error] 1226 1062
=O====== M/11.8.800.174 2013-09-14+11-34-03.667 ========
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{BF9133C2-A74E-4134-BC1F-D28B201374C6}\Flash32_11_8_800_174.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/11.8.800.174 2013-09-14+11-34-14.708 ========
2013-9-20+4-37-2.240 [error] 1226 1062
=O====== M/11.8.800.175 2013-09-20+04-36-45.400 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Temp\{ABBBE644-4A65-4E17-AB87-13035D916D44}\InstallFlashPlayer.exe" -iv 4
0001 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_175.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
=X====== M/11.8.800.175 2013-09-20+04-37-06.904 ========
2013-10-9+1-34-15.806 [error] 1226 1062
=O====== M/11.9.900.117 2013-10-09+01-34-05.752 ========
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
0013
0014
0016
0017
0018
0019 00000012
=X====== M/11.9.900.117 2013-10-09+01-34-17.101 ========
=O====== M/11.9.900.117 2013-10-12+20-57-03.512 ========
0000 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe" -maintain activex
=X====== M/11.9.900.117 2013-10-12+20-57-08.442 ========
=O====== M/11.9.900.117 2013-10-12+20-58-20.254 ========
0001
=X====== M/11.9.900.117 2013-10-12+20-58-21.599 ========
=O====== M/11.9.900.117 2013-10-12+20-58-41.057 ========
0001 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
=X====== M/11.9.900.117 2013-10-12+20-58-53.179 ========
2013-10-31+4-34-0.231 [error] 1223 1056
=O====== M/11.9.900.152 2013-11-14+02-14-16.337 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.d66fc191baffe432f5aeb605b98c4f3456cb6de6\install_flash_player_ax.exe" -install -iv 10
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_152.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.dll
0013
0014
0016
0017
0018
0019 00000012
=X====== M/11.9.900.152 2013-11-14+02-14-27.327 ========
2013-12-11+7-34-14.877 [error] 1226 1062
=O====== M/11.9.900.170 2013-12-11+07-34-04.765 ========
0001 00000011 1
0003
0004 00000018
0005
0006
0007
0008 00000013 C:\Windows\TEMP\{27AEB172-453E-4F51-8838-A96A0B571345}\Flash32_11_9_900_170.ocx
0009 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/11.9.900.170 2013-12-11+07-34-16.158 ========
=O====== M/11.9.900.170 2013-12-15+10-30-30.516 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.67e39b587695464c746800d140653cc969ed6884\install_flash_player.exe" -install -iv 8 -au 0
0001
0002
0003 00000011 1
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_170.dll
0013 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_170_Plugin.exe
0014 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0015 00000017 C:\Windows\SysWOW64\Macromed\Flash
0016 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_170.exe
0017 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0018
0019
0020 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0021
0022
0023
0024 00000012
=X====== M/11.9.900.170 2013-12-15+10-30-40.798 ========
2014-2-5+6-34-20.892 [error] 1226 1062
=O====== M/12.0.0.44 2014-02-05+06-34-07.180 ========
0001
0002 00000011 1
0004 00000013 C:\Windows\TEMP\{FEEDD719-2F4E-401C-949F-601BFFB06298}\Flash32_12_0_0_44.ocx
0005 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
0006 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
0007 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.dll
0008 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010
0011
0012 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0013
0014
0015
0016 00000012
=X====== M/12.0.0.44 2014-02-05+06-34-22.132 ========
2014-2-5+7-34-8.540 [error] 1226 1062
=O====== M/12.0.0.44 2014-02-05+07-34-05.036 ========
0002
0003
0004
0005
0006
0007 00000014 C:\Windows\TEMP\{B2198E59-806D-4B56-BCD5-58BF43E1E11D}\NPSWF32_12_0_0_44.dll
0008 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_Plugin.exe
0010 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0011 00000017 C:\Windows\SysWOW64\Macromed\Flash
0012 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_44.exe
0014
0015
0017
0018
0019
0020 00000012
=X====== M/12.0.0.44 2014-02-05+07-34-09.700 ========
=O====== M/12.0.0.44 2014-02-05+08-00-46.173 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.c1c0122cb42212923a4536ecd9576bc598161594\install_flash_player_ax.exe" -install -iv 8
0001
0002
=X====== M/12.0.0.44 2014-02-05+08-00-47.246 ========
=O====== M/12.0.0.44 2014-02-05+08-00-54.835 ========
0001
0002
=X====== M/12.0.0.44 2014-02-05+08-00-55.884 ========
=O====== M/12.0.0.44 2014-02-05+08-01-01.216 ========
0001
0002
=X====== M/12.0.0.44 2014-02-05+08-01-02.257 ========
=O====== M/12.0.0.44 2014-02-05+08-01-03.536 ========
0001
0002
=X====== M/12.0.0.44 2014-02-05+08-01-04.577 ========
=O====== M/12.0.0.44 2014-02-05+08-01-05.318 ========
0001
0002
=X====== M/12.0.0.44 2014-02-05+08-01-06.364 ========
=O====== M/12.0.0.44 2014-02-05+08-01-07.195 ========
0001
0002
=X====== M/12.0.0.44 2014-02-05+08-01-08.235 ========
=O====== M/12.0.0.44 2014-02-05+08-01-08.873 ========
0001
0002 00000011 1
0003
=X====== M/12.0.0.44 2014-02-05+08-01-13.553 ========
=O====== M/12.0.0.44 2014-02-05+08-01-24.545 ========
0001
0002 00000011 1
0004 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_44.ocx
0005 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.exe
0006 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_44_ActiveX.dll
0007 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009
0010
0011 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012
0013
0014
0015 00000012
=X====== M/12.0.0.44 2014-02-05+08-01-34.379 ========
2014-2-5+8-34-0.218 [error] 1223 1056
2014-2-16+2-34-0.216 [error] 1223 1056
2014-2-22+4-34-15.765 [error] 1226 1062
=O====== M/12.0.0.70 2014-02-22+04-34-04.430 ========
0001
0002 00000011 1
0004 00000013 C:\Windows\TEMP\{2CB9C7CD-EDC8-4A5E-9CA8-4B6D28F44994}\Flash32_12_0_0_70.ocx
0005 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
0006 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
0007 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
0010
0011
0013
0014
0015
0016 00000012
=X====== M/12.0.0.70 2014-02-22+04-34-17.015 ========
2014-2-22+5-34-14.942 [error] 1226 1062
=O====== M/12.0.0.70 2014-02-22+05-34-06.129 ========
0001 00000011 1
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_70.dll
0011 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_Plugin.exe
0012 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0013 00000017 C:\Windows\SysWOW64\Macromed\Flash
0014 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe
0015 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0016
0017
0018 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0019
0020
0021
0022 00000012
=X====== M/12.0.0.70 2014-02-22+05-34-16.119 ========
2014-2-23+7-34-0.213 [error] 1223 1056
=O====== M/12.0.0.70 2014-03-08+00-45-33.360 ========
0001
=X====== M/12.0.0.70 2014-03-08+00-45-34.454 ========
=O====== M/12.0.0.70 2014-03-08+00-45-52.206 ========
0001 00000011 1
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_70.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
=X====== M/12.0.0.70 2014-03-08+00-46-04.866 ========
=O====== M/12.0.0.70 2014-03-08+17-24-07.116 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\C3BFQ915\install_flash_player_ax.exe"
0001 00000011 1
0008
0009
0011
0012
0013
=X====== M/12.0.0.70 2014-03-08+17-24-49.972 ========
=O====== M/12.0.0.70 2014-03-10+01-25-44.574 ========
0001
=X====== M/12.0.0.70 2014-03-10+01-25-45.614 ========
=O====== M/12.0.0.70 2014-03-10+01-25-59.780 ========
0001 00000011 1
0008
0009
0011
0012
0013
0014 00000012
=X====== M/12.0.0.70 2014-03-10+01-26-12.301 ========
=O====== M/12.0.0.70 2014-03-10+22-46-16.200 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\VJJUVXD3\uninstall_flash_player.exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027 00000011 1
=X====== M/12.0.0.70 2014-03-10+22-46-33.766 ========
=O====== M/12.0.0.70 2014-03-10+23-00-35.699 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.c1c0122cb42212923a4536ecd9576bc598161594\install_flash_player_ax.exe" -install -iv 8 -au 2
0001
0002
0003
0004 00000011 1
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_70.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
0013 00000012
=X====== M/12.0.0.70 2014-03-10+23-00-44.454 ========
=O====== M/12.0.0.70 2014-03-11+02-19-03.722 ========
0001
=X====== M/12.0.0.70 2014-03-11+02-19-04.764 ========
=O====== M/12.0.0.70 2014-03-11+02-19-15.066 ========
0001 00000011 1
0008
0009
0011
0012 00000012
=X====== M/12.0.0.70 2014-03-11+02-19-26.438 ========
=O====== M/12.0.0.70 2014-03-11+02-22-24.727 ========
0001
=X====== M/12.0.0.70 2014-03-11+02-22-25.757 ========
=O====== M/12.0.0.70 2014-03-11+02-22-33.824 ========
0001 00000011 1
0008
0009
0011
0012 00000012
=X====== M/12.0.0.70 2014-03-11+02-22-42.717 ========
=O====== M/12.0.0.70 2014-03-11+02-36-33.018 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\TEHS9RE5\install_flash_player_ax.exe"
0001 00000011 1
0008
0009
0011
=X====== M/12.0.0.70 2014-03-11+02-37-16.317 ========
