I am installing e-Learning Suite on Vista 32 bit machine, all the software of the suite got installed successfully except the Presenter 8.0. It said some problem with OS version, happenned while installing Presenter. Please help to install this important software.
Kamal K Gupta, PGT Comp. Sc.
Kendriya Vidyalaya Sangathan, India
Hi!
I am Sukalyan Banga from India, Currently our institute is looking for a good interactive eLearning solution.
I need some user experience from India or, else.
please, help me with your experience.
I wants to see practically, Needs to know technical expertise lavel to run entire system, Service & Support provider in India.
Sukalyan Banga
<personal info removed by mod - kglad>
Hi Sukalyan,
Greetings from Adobe.
You can go either for Adobe Captivate 7 or Adobe Presenter 9 (which is an addin to powerpoint) which are Flash based interactive elearning tool.
You can download 30 days trial for both the softwares and check if it is what you need.
Captivate 7 :
https://www.adobe.com/cfusion/tdrc/index.cfm?product=captivate
Presenter 9 :
https://www.adobe.com/cfusion/tdrc/index.cfm?product=presenter
Mayank
sorry, but I am looking for information about adobe connect...............
HI Kamal Kant,
Can you tell me the error you got while installing presenter 8 ?
Is it possible to check the main installation log files for errors? You will find the log files at the below location:
C:\Program Files\Common Files\Adobe\Installers and look of .gz file. Extract it (for example using winrar) and open it with notepad to look for errors.
Please let me know the errors you see in the log files.
Mayank
