Hi again
Just downloaded the file and I see you have two buttons on
each slide. The buttons are what is pausing the movie. By default,
the very nature of Button and Click Box objects is to pause the
movie until your user interacts. What you can do is to double-click
one of the buttons and click the Options tab. There, DE-select the
"Pause after" check box. After you do this, click the check box at
the bottom of the dialog labeled "Apply to all". Then click the
Settings button next to the check box. Make the following
selections: Apply only changed properties and Apply to all slides.
Then click Close and OK.
After you make those changes, your movie should play right
along. However, you will probably want to change the timings of the
buttons. As after you do this, you very briefly see the buttons.
I'm guessing that won't be what you want.
Cheers... Rick
