How do I make Photoshop CS6 keyframe panning work with many clips?
chuck.keysor@sbcglobal.ne Mar 3, 2014 1:36 PMHello Photoshop experts:
I am having big troubles with applying keyframe controlled panning in Photoshop CS6. After reading chapter 10 of Photoshop CS6 CIAB, I added a simple cloud animation to my video. The original video/audio track is in Video Group 1. I pasted a simple JPEG graphic of a white cloud in to Video Group 2, without anything else in that group. Following the CIAB directions, I was easily able to make the cloud pan across the top of my video. Ah, this is easy I thought!
Then, I added a second cloud, this time it was black. I added this to Video Group 2, right after the white cloud. Here is where the troubles began..... I would highlight the image frame of the black cloud, move the playback head/cursor to the right end of the black cloud clip, then click on the "Position" clock to install a yellow diamond keyframe marker. At that instant, the selected clip of the black cloud would de-select, and the white cloud clip would select instead. As soon as the white clould was selected, then I couldn't click and drag the black cloud, as that frame was no longer selected. So, I would click the mouse back on the black cloud frame, and try and set the second key frame marker at the beginning of the black cloud frame for where I wanted the black cloud to sit at the start of the pan............ But then no motion would take place as I advanced the cursor across the frame.
So, I started a Video Group 3, and moved the black cloud into that. Then, without problems, I was able to use the key frame markers to control the panning of the black cloud across the frame,,,,,,,,,,, ah, this is easy! But then, I put in a red cloud onto Video Group 3, and guess what? It would not work, the same as before, it only wanted to jump to the black cloud clip as soon as I had set the first key frame marker on the pink cloud.
Note, underneath the first still image clip that I successfully automated the zoom function, there appears a violet shaded area under that clip, going from the starting key frame marker to the ending key frame marker. It seems as though this should be telling me something, as only the working automated panning sections have the light violet highlighting. But I can't move or eliminate that highlighting, or get it to associate with the clip I am trying to work with, after the first instance.
I have about 75 little clips I need to pan and zoom in on, and I am NOT going to make an individual Video Group for each clip! Something is wrong. I have spent about 5 hours banging my head on this today, and about 2 last night......
A) Maybe this is too confusing, but if someone can say what is wrong, I would appreciate any help.
B) Can you recommend an appropriate video (YouTube or other free source) that would shine light on this? The only videos show just one simple segment getting automated panning applied,,,,,,,,,,, my problem does not exist in that simple case.
Thanks, Chuck
