1. Re: Insanely slow export in CC
Jeff Bellune Mar 2, 2014 6:19 AM (in response to Me8190)Are you using hardware-accelerated Mercury Playback via OpenCL? Have you set Maximum Render Quality in the Export Settings? Software MPE playback is slower than hardware in many cases and if you combine that with MRQ then you can get very long renders. And if you're not scaling or deinterlacing your video, you may not need MRQ at all. Your choice of Color Correction plugins can have an effect on render time as well. If the plugin can't be hardware-accelerated by Pr, then render times can increase significantly compared to the CC tools in Pr that can be accelerated.
Cheers,
Jeff
2. Re: Insanely slow export in CC
Me8190 Mar 3, 2014 11:57 AM (in response to Jeff Bellune)Thanks for your reply Jeff. I messed around with all those settings you mentioned but had no significant changes in performance. Then I exported with AME instead of direct export and it was way faster. It took about an hour and 30 minutes. Still having slow rendering though, so I'm not really sure what else to do there...
3. Re: Insanely slow export in CC
Kevin-Monahan Mar 3, 2014 1:36 PM (in response to Me8190)Hi Me8190,
In the lower right corner of the Queue panel in Adobe Media Encoder, is the pop up menu set to "Mercury Playback Engine Software Only?" If so, change it to "Mercury Playback Engine Software GPU Acceleration (Open CL)." If you do not see hardware options, see this post for a workaround.
Kevin
