Flash : 12.0
Adobe Reader: 11.05
OS: Windows 8.1
Browser: IE 11
when launching a PDF that is classed as a portfolio I get the below error which appears to require flash to be installed.
two things im sort of observing:
If i install the windows 8 version of flash onto the machine I can open the PDF file no problem but by doiing this im not sure what file i might be over wrtiing and cause further issues down the track .
Read somewhere that the NPSWF64_12_0_0_70.dll is what adobe reader would use . copy the file to the required location and registering the dll seemed to do nothing as i get the same error.
My question is how can i get the Flash Plugin for Adobe reader to work so that I can open PDF portfolios ?
Windows 8.x only comes with the Flash Player ActiveX (for Internet Explorer); you need to install the plugin manually from http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player.exe
Thank you for your Quick Response .
I think that is what i had installed previously but since it didn't have windows 8.1 specifically i was not sure .
But again thank you for confirming and I will install this for this particular user.
