1. Re: Links not working in Reader for some
~graffiti Mar 4, 2014 9:58 AM (in response to vward26)What do you mean by they don't work? What exactly happens?
By the way, you can skip the whole adding links in Acrobat step. You can do that in ID and with the proper export functions, the links will be preserved.
2. Re: Links not working in Reader for some
vward26 Mar 5, 2014 5:43 AM (in response to ~graffiti)By nothing happening, I mean, that the cursor doesn't change into the 'hand' and the links aren't live and don't take you to the webpage.
How do I export it with the proper functions so I can skip the steps in Acrobat? Is there anything I need to do to the text before I export it or does it automatically recognize any links in the document?
Thanks for your help!
3. Re: Links not working in Reader for some
~graffiti Mar 5, 2014 7:09 AM (in response to vward26)Hmm. Sounds like something went wrong with the links. Are they spelled out (using http://www....etc) or are they hyperlinks? If they are spelled out, you could have your version of Reader set to recognize links and they may not (Edit>Preferences>General>Basic tools - Create links from URLs).
To create links in ID, highlight the text, go to your hyperlinks pallet and in the drop-down select "New link" and fill in the appropriate information. Then when you export it to PDF from ID, in the "General" settings section under "include" select "Hyperlinks".
There are other options you may want to be aware of but that's better asked about in the ID forum.
4. Re: Links not working in Reader for some
vward26 Mar 5, 2014 7:23 AM (in response to ~graffiti)Ok. Thank you. They are all usually spelled out and not hyperlinks. I will have them check their settings and also try just doing this in ID from now on too. I'm obviously up for anything that involves less steps!
5. Re: Links not working in Reader for some
~graffiti Mar 5, 2014 8:07 AM (in response to vward26)More than likely, that preference setting is the culprit but yes, once you get used to creating the links in ID, you'll probably like it better. Good luck.
