Hi Wayne
I have a lot of camtasia vids in a webhelp project, swf (not
legacy) and flv and they are working okay for me.
Re 'no navigation' - the first thing that comes to mind is a
missing baggage file, but it sounds like you already covered that.
How many baggage files are you importing?
for example baggage files I have:
movie.swf
movie_config.xml
movie_controller.swf
movie_preload.swf
Also remember to bring in flashobject.js - forgetting that
caused me probs getting content to play.
Are the baggage files existing in the same folder as the the
html page?
I had some probs getting things to work to begin, but my
method now is to import baggage files into the correct folder
first, then import the html file as produced by Camtasia, then add
the link from the Robo htm file to the Camtasia produced html file.
As for the link to the SSL folder, that sounds like the path
for the link as set in Robo, but again, if you've removed and
re-added the link, not sure what's going on there.
Sure you've already thought of it, but did you remove the
folder from within RoboHelp or using Windows Explorer?
The only thing I can think of to test it would be to produce
the vid again from within camtasia but use a different file name,
then try bringing the baggage files into a new 'test' target
folder, then import the html file and set up the link etc.
I've been using X5 and Camtasia 3.x & 4.x
Cheers
Karl
