Locked
Linking when using Text (hyperlink) or Text (multiline)
Guest
Mar 04, 2014 Mar 04, 2014
   New to web apps and I have a question.
When I enter a NEW ITEM, for example, Event Name- and set the Field Type to Text (hyperlink) or Text (mutliline), when I insert it in the layout and then view it on the page, it is a Clickable link. But the link goes nowhere. It goes to a "oops nothing is here" page. And the URL is something like event%title%.
Is there a way to have the clickable link just go to a page which futher outlines the event that was clicked on?
Web apps
664
What is the link you are putting in. Can you show some examples? The urls you are entering could be incorect if its not finding the page (404).
Guest
I will include screenshots as that might clear it better (or not). Thank you first for answering Liam.
What the general settings look like:
Liam- is this the URL you are talking about? If so- how would I define it so that every event when clicked goes to the right place when using One Web App (Add Events!)- but then just adding items under that event?
Step 1: Add new field
Step 2: Insert into Layout of Web App (bottom Item) - {tag_event_title}
Step 3: Check the site and click on the link "Title of event, where does it go"
Step 4: This is where it currently goes
What I would love to happen in a perfect world:
Kind of how the EVENT module works, how the title when clicked links to a more full description of the event... I know WEB APPS are different, but like I said "in a perfect world." Seems like that may not be possible, if only because I don't see there is a "detailed event" layout, like Events has (List and Detailed layout customization).
let me know if this doesn't help clarify.
Are you trying to link to the detail view of the event?
If this is the case then you do not do it that way.
You have the following:
{tag_name} - Renders the item name wrapped in a link
{tag_button,Your Text} - Renders a link with custom text to the detail view
{tag_itemurl_withhost} - Just renders the full url
{tag_itemurl_nolink} - Just renders the path.
You use that custom field if you wanted to link to something and that will work depending on what you put in each web app item, not the web app layouts itself.
Guest
Yes, I want to link to the event detailed description if the Title is clicked on. Let me look into what you have written and get back if I cannot make sense of it.
Mar 05, 2014 Mar 05, 2014
If you read my post above I gave you the tags for that.
the last two you would do <a href="THETAG">View Detail</a> etc.
Guest
Mar 09, 2014 Mar 09, 2014
Thank you for your help Liam. I solved this by going back through my settings. I had clicked the Disable Detail View when setting up the app.
