0 Replies Latest reply: Mar 5, 2014 2:32 PM by SucramLegiew RSS
    Oracle error ORA-01461when trying to insert into an ORACLE BLOB field
    SucramLegiew Community Member
      I am getting Oracle error ‘ORA-01461: can bind a LONG value only  for insert into a LONG column' when trying to insert into an ORACLE BLOB field. The error occurs when trying to insert a large BLOB (JPG), but does not occur when inserting a small (<1K) picture BLOB.(JPG). Any ideas?
      BTW, when using a SQL Server datasource using the same code.... everything works with no problems.
      ORACLE version is 11.2.0.1
      The ORACLE datasource is JDBC using Oracle's JDBC driver ojdbc6.jar v11.2.0.1 (I also have tried ojdbc5.jar v11.2.0.1; ojdbc5.jar v11.2.0.4; and ojdbc6.jar v11.2.0.4 with the same error result.)
      Here is my code:
      <cfset file_mime = Lcase(Right(postedXMLRoot.objname.XmlText, 3))>
      <cfif file_mime EQ 'jpg'><cfset file_mime = 'jpeg'></cfif>
      <cfset file_mime = 'data:image/' & file_mime & ';base64,'>
      <cfset image64 = ImageReadBase64("#file_mime##postedXMLRoot.objbase64.XmlText#")>
      <cfset ramfile = "ram://" & postedXMLRoot.objname.XmlText>
      <cfimage action="write" source="#image64#" destination="#ramfile#" overwrite="true">
      <cffile action="readbinary" file="#ramfile#" variable="image_bin">
      <cffile action="delete" file="#ramfile#">
      <cfquery name="InsertImage" datasource="#datasource#">
      INSERT INTO test_images
      image_blob
      SELECT
      <cfqueryparam value="#image_bin#" cfsqltype="CF_SQL_BLOB">
      FROM          dual
      </cfquery>
