Hello,
I have been playing with installing Flash Player 12.0.0.70 via group policy. I was upgrading from 11.8.800.94 to 12.0.0.70.
The upgrade seems to have worked ok, I am able use flash player and when I verify the install it congratuates me that I have the latest version.
When I check all of the files they are all the right version.
However when I check the flashinstall.log it states the following error - 2014-3-4+15-22-11.12 [error] 1226 1062
Is this something I should be worried about?
The PC is Windows 7 32Bit, Internet Explorer 9.
Thanks in advance
Here is the full log -
=O====== M/11.8.800.94 2014-03-04+13-34-38.039 ========
0000 00000010 "C:\WINDOWS\TEMP\InstallAX_11_8_800_94.exe" -install -msi
0001
0002
0003 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0004
0005 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash32_11_8_800_94.ocx
0006 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0007 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0008 00000023 C:\WINDOWS\system32\Macromed\Flash\activex.vch
0009 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0010 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011 00000012
=X====== M/11.8.800.94 2014-03-04+13-34-41.003 ========
2014-3-4+13-34-46.962 [error] 1226 1062
=O====== M/11.8.800.94 2014-03-04+13-34-45.121 ========
0000 00000010 "C:\WINDOWS\TEMP\InstallPlugin_11_8_800_94.exe" -install -msi
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32_11_8_800_94.dll
0014 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_8_800_94_Plugin.exe
0015 00000024 C:\WINDOWS\system32\Macromed\Flash\plugin.vch
0016 00000017 C:\WINDOWS\system32\Macromed\Flash
0017 00000022 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerPlugin_11_8_800_94.exe
0018 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0019
0020
0021 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0022
0023
0024
0025 00000012
=X====== M/11.8.800.94 2014-03-04+13-34-48.148 ========
=O====== M/11.8.800.94 2014-03-04+14-22-09.432 ========
0000 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe -uninstall activex -msi
0001
0002
0003 00000018
0004
0005
0006 00000018
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020 00000012
=X====== M/11.8.800.94 2014-03-04+14-22-11.257 ========
2014-3-4+14-22-15.157 [error] 1226 1062
=O====== M/12.0.0.70 2014-03-04+14-22-05.188 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001
0002 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0003
0004
0005 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash32_12_0_0_70.ocx
0006 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
0007 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
0010
0011
0012 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0013
0014
0015
0016 00000012
=X====== M/12.0.0.70 2014-03-04+14-22-16.936 ========
=O====== M/11.8.800.94 2014-03-04+15-22-06.971 ========
0000 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_8_800_94_Plugin.exe -uninstall plugin -msi
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022 00000012
=X====== M/11.8.800.94 2014-03-04+15-22-07.190 ========
=O====== M/12.0.0.70 2014-03-04+15-22-04.631 ========
0001 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32_12_0_0_70.dll
0013 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_12_0_0_70_Plugin.exe
0014 00000024 C:\WINDOWS\system32\Macromed\Flash\plugin.vch
0015 00000017 C:\WINDOWS\system32\Macromed\Flash
0016 00000022 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerPlugin_12_0_0_70.exe
0017 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0018
0019
0020 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0021
0022
0023
0024 00000012
=X====== M/12.0.0.70 2014-03-04+15-22-12.525 ========
Since all it working, maybe you should leave it at that. But most likely the same issue will come back with the next update.
It would be worthwhile to once perform a clean install, and see if the issue disappears.
It seems that the installer was unable to replace C:\WINDOWS\system32\FlashPlayerCPLApp.cpl and C:\WINDOWS\system32\FlashPlayerApp.exe with their newest versions.
A clean install (http://forums.adobe.com/thread/928315) should fix that.
Hi Pat,
Thanks for replying, much appreciated.
I did check those files and they have upgraded, they are the correct version and in case of FlashPlayerApp.exe do work.
Is the 183 code an indicator of failure?
As the files seem to have upgraded and do work, should I be concerned?
Steve
Hi Pat,
We performed a clean installed as directed in http://forums.adobe.com/thread/928315 and we still got the same 183 errors.
As it's working I'll probably go with it, we will be updating quite a few PCs so will tread carefully initially.
Thanks for your help and getting back me.
