1. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
John T Smith Mar 4, 2014 2:51 PM (in response to onebobtoomany)What is your exact brand/model graphics adapter (ATI or nVidia or ???)
What is your exact graphics adapter driver version?
Have you gone to the vendor web site to check for a newer driver?
For Windows, do NOT rely on Windows Update to have current driver information
-you need to go direct to the vendor web site and check updates for yourself
ATI Driver Autodetect http://support.amd.com/en-us/download/auto-detect-tool
nVidia Driver Downloads http://www.nvidia.com/Download/index.aspx?lang=en-us
http://helpx.adobe.com/premiere-pro/kb/error---preludevideo-play-modules.html
2. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
onebobtoomany Mar 4, 2014 3:02 PM (in response to John T Smith)Hello John,
Thanks for responding. My cards are NVidia (2 nVidia GeForce GTS 250). I know they are unsupported but they work still the same with everything else. I will upgrade on my next build. I updated my driver last night to the latest version 334.89.
Robert
3. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
John T Smith Mar 4, 2014 3:13 PM (in response to onebobtoomany)Some previous discussions that may help... or may not, but free to read
2 cards and 3 monitors http://forums.adobe.com/thread/875252
-and http://forums.adobe.com/thread/876675
Dual Card SLI http://forums.adobe.com/thread/872941
4. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
onebobtoomany Mar 4, 2014 3:52 PM (in response to John T Smith)Hello John,
Thanks again for the quick reply. I just finished reading the previous discussions you provided. I don't think the dual cards are the problem, I only have them in order to use 4 monitors. I understand that only one card will be used for GPU, and as it is, since my cards aren't supported, that issue is moot, even with Harm Millaards hack, which I did try to no avail in this case The afore mentioned hack did improve performance with my CS6 non cloud version somewhat, which motivates me to upgrade my cards in the future to take advantage of supported GPU (on my next build and when I can afford it). All of my non cloud CS6 Master Suite products work perfectly with my dual card configuration without a hitch. The only problem seems to be with Premiere Pro CC.
Robert
5. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
onebobtoomany Mar 5, 2014 12:22 AM (in response to onebobtoomany)Hello John,
I mentioned at the start of this string that when opening the program it would always stall at ImporterQuicktime.prm, as though it were searching for the plug-in, and then It crashes and displays the error message " Premiere Pro could not find any capable video play modules. Please update your video display drivers and start again."
I followed a hunch and located ImporterQuickTime.prm.
C:\Program Files\Adobe\Adobe Premiere Pro CC\Plug-ins\Common\ImporterQuickTime.prm
I found that if I right click ImporterQuickTime.prm and use the open command it will open Premiere Pro CC. However, since I jumped straight to this plug-in it seems that not all of the other plug-ins had loaded. I was still able to open a project file and run it.
Somehow this corrected the original problem. After closing out Premiere Pro CC, I restarted it normally from the desktop and voila!, it opened without a hitch.
I'm clueless as to why this worked, but it did. Hopefully this will be a useful solution for others.
I still have to take Premiere Pro out for a test spin to be sure there aren't any other bugs, but that will be tomorrow.
Thanks again for your help.
Robert
6. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
onebobtoomany Mar 5, 2014 8:18 AM (in response to onebobtoomany)Hello John,
I think I was a bit premature when I thought I found a fix. After I started my system up this morning I tried Premiere Pro CC and the problem was there again. I tried starting the program from the ImporterQuickTime.prm plug-in, but it didn't work this time.
I guess I'm back to square one.
Maybe the temporary fix will provide a clue to someone else as to what to try next.
Robert
I'll keep testing in the mean time.
7. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
John T Smith Mar 5, 2014 8:37 AM (in response to onebobtoomany)Hmm... I have CS5 (home video so no income to pay for monthly CC) and I do not have Quicktime installed... and have never had your problem
Only other thing I can suggest is...
Adobe/Jive have a BAD title for the SEARCH THIS FORUM function
Go to http://forums.adobe.com/community/premiere and, in the area just under Ask a Question, type in
You may now read previous discussions on this subject... be sure to click the See More Results at the bottom of the initial, short list if the initial list does not answer your question
8. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
onebobtoomany Mar 5, 2014 9:14 PM (in response to John T Smith)Thanks again John for the help,
As it turns out the problem was the display drivers (kinda-sorta). The clue was the stall at ImporterQuickTime.prm followed by the error screen referring to the inability to find a suitable driver. A long time ago I tested the JAWS software so I could have a better understanding of what a vision impaired person would hear when scanning an accessible website. I never bothered to remove this software. When I checked my device drivers on Windows I discovered that I had a virtual mirror driver by Freedom Scientific (The creators of JAWS). After removing the software and the driver I was able to open Premiere Pro CC normally, even after repeated tests and reboots of my computer. It has worked flawlessly every time.
As far as my previous success (and subsequent failure), I'm still clueless as to why that worked, albeit temporarily.
This is a fluke cause of failure and the fix probably won't help anyone else.
Robert
9. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
John T Smith Mar 6, 2014 8:27 AM (in response to onebobtoomany)Good troubleshooting... a 3rd party software driver is not something I would have suggested... that driver was clearly "hooking" into a part of the OS that then caused problems with PPro
10. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
Ian Buck Jun 4, 2014 7:07 PM (in response to onebobtoomany)Thank you for this. I have been trying to fix this issue for 6 hours now. It turns out my NVIDIA Graphics card is causing the problem but my intel one works. I am very happy. I now get to sleep soundly.
11. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
unplugged Sep 7, 2014 4:20 AM (in response to onebobtoomany)Hi i had the same problem as this. I went into device manager and disabled my AMD Graphics card (which made my screen screw up) I then managed to open Adobe premiere pro without a problem. Does anyone have a fix which can help run the Graphics card as well as open Premiere?
12. Re: Premiere Pro CC stalls at - ImporterQuickTime.prm - "Unable to find any capable video play modules"
Shoshik Nov 7, 2014 4:44 AM (in response to onebobtoomany)Try to delete TEMP "c:\Users\XXX\AppData\Local\Temp"
Premiere and After Effects again works fine!!!
Ondrej
