My project has an empty file which cannot be deleted but was ignored by RH9. In converting to RH11 I get the following message: "Error - node */Views/<folder name>/<folder name>/SBLCRVAL.htm already exists." However, there is no other file by that name in the project. There is a similar one which I renamed and everything works fine in RH9, but I cannot convert to RH11.
Have you tried deleting the .cpd file first and then upgrading?
I just tried it, but I still get the same error.
Can you post a screenshot of what you’re seeing? Use the camera icon in the web interface.
This is a Source Control issue – you probably haven’t completely checked out all components of the project before you upgraded it. You might find for info/assistance over in this forum - http://forums.adobe.com/community/robohelp/robosource_control
The files are automatically checked out as you do the upgrade. However, I tried checking them all out ahead of time and it made no difference.
Hi there
I think I'd save a copy of the offending file in a safe place, then delete it from the project. After the upgrade completes, then import it back into the project.
Cheers... Rick
