Show 5 replies
1. Re: Guide to infinite menu
Gorka Ludlow May 22, 2007 9:22 AM (in response to purple_am)Hello,
this is what i would do:
1.- read the data for the gallery (we know it is not infinite, though we don`t know the length until we receive all the data) with your favorite method (loadVars or XML)
2.- Loop through the data and add images to the gallery dynamically with attachMovie. attachMovie should be attaching a MovieClip in your library which should be exported for actionscript. Everytime you attach a movie you can position it and send some initial values for it to work differently than any other.
3.-- In the MoviClip you'll be loading dynamically you should have a place to put the thumbnail, or image (loader, scroolpane, another movieclip, etc), and make sure you send the file name to the movieclip so that it knows what to load.
If you need some extra pointers feel free to ask
Cheers
Gorka -
2. Re: Guide to infinite menu
purple_am May 22, 2007 11:47 PM (in response to purple_am)well i understood steps 1 and 2 ... but am confused with these ...
"Everytime you attach a movie you can position it and send some initial values for it to work differently than any other.
3.-- In the MoviClip you'll be loading dynamically you should have a place to put the thumbnail, or image (loader, scroolpane, another movieclip, etc), and make sure you send the file name to the movieclip so that it knows what to load."
Can i have some more precesions please.
Good day
am -
4. Re: Guide to infinite menu
Gorka Ludlow May 23, 2007 9:53 AM (in response to purple_am)attachmovie works this way:
attachmovie(movie_clip_identifier, new_instance_name, depth [, initObject]);
you could use this:
attachmovie(picture, 'picture'+i, this.getNextHighestDepth(), {_x:i* picture_width + offset, _y:i*picture_height+offset, File:var_file}]);
i++;
**assuming picture is the identifier for the movieclip you'll attach
'picture'+i - assigns a different name for every mc you attach
_x and _y - are used to place the images in the moviclip that is going to hold them
File - will be a variable inside the picture instance created that you can use to tell a loader or scrollpane what content to load (more code ahead)
inside picture mc:
// you'll need a loader component named loader in the stage
var File:String;
function init():Void{
loader.contentPath = File;
loader.load();
init();
That's what I meant, let me know how you do
Cheers
Gorka -
5. Re: Guide to infinite menu
purple_am May 25, 2007 1:59 AM (in response to purple_am)thanks guys, am onto it.
