Show 3 replies
1. Re: Can premiere edit 10 bit 4-2-2 files encoded using Atomos NinjaNinja2
shooternz Mar 11, 2014 2:21 PM (in response to DVDmike)Yes (Samurai), Yes, No
2. Re: Can premiere edit 10 bit 4-2-2 files encoded using Atomos NinjaNinja2
DVDmike Mar 11, 2014 7:44 PM (in response to shooternz)Shooternz, just to be clear, I dont have to use the Samurai version because my camera is a D-SLR with HDMI output? What do you encode as for use in PP CC? It says you have two options, Prores or DnxHD. Are there more encoding options or does PP CC handle one of thes formats navitely?
3. Re: Can premiere edit 10 bit 4-2-2 files encoded using Atomos NinjaNinja2
shooternz Mar 11, 2014 6:58 PM (in response to DVDmike)I use Prores natively.
You can do a test you know... if you have everything.
