When I edit sound in a PowerPoint deck using Presenter 9 it plays well in preview, but when publish the deck in flash, the audio is fouled up on the slides that I edited. Either the audio ends abruptly at the end of the slide or the audio on the beginning off one slides overlaps with the next slide. I could use help.
When I delete all of the audio and start again, I still have audio issues.
Is this a known problem?
HI ,
I have not encounterd this problem yet. Did you try following :
Publish the Presentation in a different folder and check again.
Use save as to save this presentaion with different name and publish and verify.
if issue is still present than please share few information with us.
Is this audio issue is happening for one presentation or for all Presentaitons ?
Are you playing published swf locally or from a server ?
Can you please share sample file if possible ? Package this presentation mail to sunsahu@adobe.com.
This will help us to figure out the issue and I will try to resolve this issue ASAP.
Sunil
Adobe Presenter Engg Team
This issue was happenning because of ppt Presentation. Saving Presentation as PPTx resolved the issue.
Please confirm so that other can take help of this Post.
Sunil
