I am trying to implement this layout to my Robohelp Project, but I get the IPad layout instead of the previewed Desktop layout that is in the screenshot. All other Desktop layouts work fine with me this one does not work with me. It is the first one here: http://helpx.adobe.com/robohelp/robohelp-screen-profiles-layouts.html
I can't seem to get the Desktop layout to work, and I need to have the printer button, I keep getting the Ipad layout instead, any thoughts??
You have to check the SSL settings. Be sure to link the Desktop Layout
to the Desktop Screen Profile. You probably have the iPad Screen Layout
linked to Desktop.
Kind regards,
Willam
Thank You for the answer, I found out that the window need to be larger in order for the layout to switch to desktop version, but I want to use the desktop layout always, is there a setting to decrease the width so the window does'nt have to be large all the time?
SOLVED:
Had to modify main.css
It sounds like you want all users to have the desktop layout regardless of which device they are using. If that is the case, just generate that layout. It is not necessary to generate all the layouts, only those you want.
