In testing the RH HTML output, I've had a review comment that there were issues with viewing the online help with IE 11 and also Google Chrome. In searching for possible fixes, I came across a fix for both.
IE11 issue -- http://helpx.adobe.com/robohelp/kb/robohelp-output-issues-ie-11.html
Google Chrome issue -- http://helpx.adobe.com/robohelp/kb/webhelp-issues-robohelp-versions-10.html
The IE11 fix has two files in the fix -- whutils.js and whver.js
The Google Chrome fix has four files, two of which are the same as in the IE11 fix.
With issues on both of these platforms, does anyone know if those files will work for both issues?
If I update whutils.js and whver.js for the IE11 fix, and then update those same files for the Chrome fix, will I still have the IE11 fix??
I forget which order they came out, but if you load them in order, your earlier fix will be preserved.
The IE11 fix files are dated 12/2013, and the Chrome files are dated 01/2014, so I'll load the IE11 files first and then the Chrome files (which will overwrite the IE11 files). I'll see how that goes, although it'll probably take a while to get it reviewed by the developers.
Thank you.
You wonāt need a developer to review it ā you can test it yourself quite quickly ;>)
The latest version also contains the fixes of the earlier version. It's
safe to just take the last one.
Kind regards,
Willam
Thanks! Iāve done that and it tests ok on IE11. Now to test it on Chrome. āŗ
Re: RH10 and IE11/Google Chrome issues and fixes<http://www.infor.com/>
Dan Cotton ā Information Developer, Sr.
I have edited your post to remove your mobile number and email address. You really don't want to post that on any forum.
Thank you.
