1. Re: How do I center a slideshow containing various width images?
Nancy O. Mar 9, 2014 6:04 PM (in response to Noradc)Without a link, I have no idea what you're talking about. I don't see anything in your code fragments that suggest your cycle images are opening in a new page.
Nancy O.
2. Re: How do I center a slideshow containing various width images?
Noradc Mar 9, 2014 6:44 PM (in response to Nancy O.)Hello Nancy O,
My website is... http://norachristians.com
The slideshow on the first page works the way that I want it to.
The thumbnail images are found at the following website addresses, they serve as links to the pages where the additional slideshows are...
http://www.norachristians.com/still_image.html
http://www.norachristians.com/painting/watercolor.html
Thank you.
Nora
3. Re: How do I center a slideshow containing various width images?
Nancy O. Mar 10, 2014 8:22 AM (in response to Noradc)Try these changes to your CSS:
.cycle-slideshow {
margin: 0 auto;
border: 1px solid #bbb;
background: #333;
margin-bottom: 20px;
.footer_copyright {
position: relative;
clear: both;
font-family: Arial, Helvetica, sans-serif;
font-size: .9em;
margin-left: 0px;
margin-bottom: 25px;
z-index: 5;
color: #CCC;
letter-spacing: .6px;
Z-index (stacking order) serves no purpose except when used on positioned elements. You have used it several times where it is not necessary.
Nancy O.
4. Re: How do I center a slideshow containing various width images?
Noradc Mar 11, 2014 8:55 PM (in response to Nancy O.)Hello Nancy 0,
Thank you for the information. I didn't know that about the position and z-index. I made the changes to the css as suggested. But no change happened. So I tried changing the following in my html code so that it would be the same as malsup's sample for comparison...
data-cycle-fx=fade to scrollHorz
data-cycle-timeout=0 to 2000The first image slide still loaded from the left and then centered on the page. Then the image slides scrolled along the page from right to left. I then saw that Malsup has the example showing towards the bottom of its webpage. After decreasing the window size, I saw that the first image appears very quickly from the lower left and then to the center as does mine except on a smaller scale. I've come to the conclusion that this is a normal action for the javascipt function. But would it be too much to ask if this could be less noticeable? Also, when I made the changes to my slideshow to scroll, I noticed that as the image slides scrolled out of the slideshow, they extended beyond the slideshow border and even the container div. I notice that this doesn't happen in the malsup example. Malsup's image slides are not visible beyond the edge of the background color. How can I have my slideshow images stop at the edge of the slideshow background color also? I greatly appreciate your advice. Thank you very much.
Noradc
5. Re: How do I center a slideshow containing various width images?
Nancy O. Mar 12, 2014 12:09 PM (in response to Noradc)Flash of unstyled content (FOUC) occurs most often in older IE browsers or on very slow internet connections. I don't see any delays on your site, Malsup's site or in my own Cycle2 slideshows. So I'm guessing this is only a problem at your end.
Nancy O.
