1. Re: Huge file size?
jackblackweb Mar 12, 2014 10:24 PM (in response to Erniegar)Hey Ernieger,
What platform?
jpg files seem to be deprecating.
png files may work.
Jack
2. Re: Huge file size?
SeanWilson Mar 12, 2014 11:43 PM (in response to Erniegar)If you publish the file to DCR you'll regain the file size. Director decompresses/expands JPEGs on import so that they display as quickly as possible, without requiring prior decompression
3. Re: Huge file size?
Milky_au Mar 13, 2014 3:56 PM (in response to SeanWilson)just an idea...
with the property inspector turned on
select the bitmap tag
under 'compression' change it from 'Movie Setting" to 'JPEG'
I believe Director brings in all graphics uncompressed - only compresses them upon publishing
So if you want to publish an .exe with lots of large graphics - and you don't turn on 'Compress Files (shockwave format)' under files - in the publish settings,
or you wish to get your files even smaller - then you can play around with lower jpeg settings
4. Re: Huge file size?
Erniegar Mar 17, 2014 12:42 PM (in response to Milky_au)Hi all,
Unfortunately these suggestions are not working...
Its still a huge filesize when I import a png (bigger even!)
Its already set on the jpeg settings and changing that does not help.
I am instructed to submit in dxr format so need to do so.
I am using 10.1 on Windows 7.
With a deadline looming, I'd be very grateful for any more suggestions...?
Thanks...
5. Re: Huge file size?
Erniegar Mar 17, 2014 1:34 PM (in response to Erniegar)I am now able to submit in dcr format, so alls well that ends well, with thanks to all....
