I have Windows 7 w/SP 1 and IE 10. Flash Player quit working morning of Mach 12; did work the evening before. I un-installed Flash Player after numerous attempts of following the help on enabling it. Then was unable to re-install. I have followed the uninstall/install instructions on the Flash Player web site many times without success.
As a side note this is a fresh install of windows after re-formatting the HDD the last week of February this year.
Thank you very much! Of all the stupid little things, Shockwave had been disabled. Enabling it fixed the problem.
You should be able to do a "clean install" http://forums.adobe.com/message/4041846
Already tried that, doesn't work.
Hello,
When you say "Then was unable to re-install." What do you mean? Was there an error during installation, or did it install, but Flash does not display?
Please post the contents of the FlashInstall.log file? If you have a 64-bit OS, there will be two files, please post both. Locations are:
If the files are very large, you can post just the last portion, from March.
Thank you in advance.
Maria
No error messages displayed as long as I shut down IE at some point. Flash does not display and is not "found" by windows.
64-Bit:
=O====== M/12.0.0.77 2014-03-14+16-21-55.314 ========
0000 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.c1c0122cb42212923a4536ecd9576bc598161594\install_flash_player_ax.exe" -install -iv 8 -au 1
0001
0002
0003 00000011 1
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_77.ocx
0007 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
0008 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
0009 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012 00000012
=X====== M/12.0.0.77 2014-03-14+16-21-58.016 ========
32-bit:
0001
0002
0003 00000011 1
0005
0012 00000012
Hi UncaPathy,
The log files indicate a successful installation with no errors. Have you tried the troubleshooting steps posted at http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html, specifically the 'post-installation issues' section?
Maria
