Adobe Community
All community
This category
This board
Knowledge base
Users
cancel
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results forÂ
ShowÂ
 onlyÂ
Search instead forÂ
Did you mean:Â
Global community
Language:
Deutsch
English
Español
Français
Português
日本語コミュニティ
í•œêµ ì»¤ë®¤ë‹ˆí‹°
Sign In
Home
ColdFusion
Discussions
chart ssl message
Home
ColdFusion
Discussions
chart ssl message
Upvote
chart ssl message
Guest
/t5/coldfusion-discussions/chart-ssl-message/td-p/537063
May 29, 2007
May 29, 2007
Hi i have a secure ssl page, with a cfchart on.
when a user views the page they get a alert message, "this page contains both secure and non secue etc."
i know this is caused by the standard chart web links, but how can i get rid of this message?
Advanced techniques
353
Follow
More
Reply
Reply
Be kind and respectful, give credit to the original source of content, and search for duplicates before posting.
Learn more
1 Correct answer
Daverms
Advocate
May 29, 2007
May 29, 2007
Daverms
Advocate
May 29, 2007
May 29, 2007
Hi John,
What happens if you remove those <cfif> </cfif> blocks?
Upvote
Jump to answer
5
Jump to latest reply
Daverms
Advocate
/t5/coldfusion-discussions/chart-ssl-message/m-p/537064#M49080
May 29, 2007
May 29, 2007
Try replacing all your image src's with their absolute path's, also all of your '
http://'
entries need to be changed to 'https://'
Upvote
Follow
More
Reply
Reply
Learn more
Guest
AUTHOR
/t5/coldfusion-discussions/chart-ssl-message/m-p/537065#M49081
May 29, 2007
May 29, 2007
In Response To Daverms
i have no images or links on the page, all i know is that cfchart has hidden links which are http.
so that is what is causing the issue, but how can i change these hidden links to https?
Upvote
Follow
More
Reply
Reply
Learn more
Daverms
Advocate
/t5/coldfusion-discussions/chart-ssl-message/m-p/537066#M49082
May 29, 2007
May 29, 2007
In Response To Deleted User
Hi John,
Try MikerRoo's solution.. It will work... You can find that
here
Upvote
Follow
More
Reply
Reply
Learn more
Guest
AUTHOR
/t5/coldfusion-discussions/chart-ssl-message/m-p/537067#M49083
May 29, 2007
May 29, 2007
ok i have tried adding the code below but i get this error
Diagnostics: Variable BUSESSL_FIX is undefined.
The error occurred on line 144.
any ideas what i need to do
Upvote
Follow
More
Reply
Reply
Learn more
Correct answer by
Daverms
Advocate
/t5/coldfusion-discussions/chart-ssl-message/m-p/537068#M49084
May 29, 2007
May 29, 2007
Hi John,
Upvote
Follow
More
Reply
Reply
Learn more
Post Reply
Preview
Exit Preview
never-displayed
You must be signed in to add attachments
never-displayed
Â
Documentation
ColdFusion User Guide
