I've run into this same problem with the Flex Data Services
test drive. I want to load the sample apps into FlexBuilder so that
I can set some break points and learn more about them. When I try
to create a project using Flex Data Services/compile app locally
Root Folder: C:\fds-tomcat\webapps\ROOT
Root URL:
http://localhost:8600/ROOT.I get the same 3 errors in the Output panel:
The definition of base class Locale was not found
Could not resolve<mx:Application> to a component
implementaion
unable to load SWC fds.swc: multiple points
I am on Flex 2.0.143459. Do I need the fix you referenced in
your previous post? If so, could you repost the link since the
exact link got truncated? Thank you very much.
P.S. Seems odd to me that Adobe doesn't seem to be monitoring
this forum. Lots of questions seem to go unanswered and it often
seems that junior members are trying to help each other. Where are
the evangelists and experts that want Flex to take off and become
as pervasive as Flash? The Flash Forum is very active with
questions getting answered in a matter of hours if not minutes
sometimes. Is Adobe really serious about Flex?
