Show 5 replies
1. Re: Can't add dip to black to a clip
Qengineering Mar 17, 2014 2:42 PM (in response to jaymcdonald)Are you dragging the effect to the END of the clip?
Try dragging the effect to inside the clip near the end.
2. Re: Can't add dip to black to a clip
jaymcdonald Mar 17, 2014 2:45 PM (in response to Qengineering)Dragging the transition to any spot on the clip gives the same result - the hand with the crossed out cicrle.
3. Re: Can't add dip to black to a clip
JSS1138 Mar 17, 2014 4:36 PM (in response to jaymcdonald)You sure you're dragging it to the video portion?
4. Re: Can't add dip to black to a clip
jaymcdonald Mar 18, 2014 7:20 AM (in response to JSS1138)Yes. It looks like I may have encountered a bug. I'm running CS5 under Mountain Lion. I had googled to see if there were any known issues, but everything seemed to say they were compatible with no problems. I have also noticed a similarly weird issue on the UI of another application.
5. Re: Can't add dip to black to a clip
jaymcdonald Mar 18, 2014 12:51 PM (in response to jaymcdonald)Well, out of frustration, I uninstalled the whole Creative Suite, then reinstalled and ran all the updates again. It seems to be working properly now. Go figure.
