quote:and _time is one of the ones listed.
Any form field name, from the cfform tag or an HTML form, that ends in one of the following suffixes invokes server-side form validation:
quote:
Form entries incomplete or invalid.
quote:
Originally posted by: Newsgroup User
angplange wrote:
> Help! I have an app that will be accepting a POST request to a page from an
> external app, and I have no control over the field names it's submitting.
> Unfortunately one of them ends with _time, so CF is trying to validate the
> data? How do I get around this? I'm using CFMX 6.1 on Windows...
That is going to be a challenge. I personally do not know of any way to
disable ColdFusion automatic form validation based on field names.
The only thought I have is that you could use some kind of web service
code to rewrite the request headers before it is handed off to
ColdFusion. But that could be tricky.
quote:
Originally posted by: cf_dev2
Have you tried defining your own validation handler with cferror? If a custom handler overrides the default CF handler, you could code it to do whatever you want.
Look into CFERROR
quote:
Originally posted by: Abinidi
If you have access to the server, you could technically edit the cfforms.js file in the CFIDE folder and comment out/ edit the "time" validation?
I have not done it before, but would it work?
function _CF_checktime()
