I have created a style in robohelp for autonumbers, but i am not able to stop the number sequence and start from "1". As the number is displayed in sequence.
For example, i want this sequence in Auto numbers. 1 - 4 and start again from 1 - 4.
Please advice.
Hi there
Press Enter to create a new line. Sure, it will say 5, Now press Enter twice. There should now be a blank line between the end of the first sequence and the beginning of the next sequence. Turn numbering back on and you should be back to 1 again.
Cheers... Rick
Thanks for your reply.
But still i am facing the problem. When i click enter twice i will be on the new line, but when turn back numbering it continues. It will not start from 1.
Harish
Right click the item whose number you want to change. There will be an option Bullets and Numbering where you can set a new number, but it will not work. There is also an option List Style where you can set a new number and it will work.
Do you create printed documentation?
Hi
You can restart numbering at 1, by right click on it select "Bullet Numbering" or list Style.
Or if using Auto number for paragraph style, then you can create a custom sequence by selecting new in auto number dialog.
Please let me know if it is not working for you.
Amit Jha
