1. Re: Automap Paragraph Styles and Exclude combination
Willam van Weelden Mar 27, 2014 12:09 PM (in response to Sreekanth_S)Can't you select automap in the conversion settings window, and then select the styles you want to exclude and exclude them manually?
Ideally, you could save the IFS so you should only have to do this once.
Kind regards,
Willam
2. Re: Automap Paragraph Styles and Exclude combination
Jeff_Coatsworth Mar 27, 2014 12:12 PM (in response to Willam van Weelden)Psst - .isf file Willam ;>)
3. Re: Automap Paragraph Styles and Exclude combination
Sreekanth_S Mar 27, 2014 12:21 PM (in response to Willam van Weelden)Hi Willam
If I understand right, you are suggesting me to exclude the automapped styles manually. For example, in the Conversion Settings window, I select Automap in the RH Styles list and then select the Exclude check box.
I am aware of that process. However, I want to eliminate the process of automapping (and exluding) each style manually. What I am expecting is, if I select the Automap Paragraph Styles check box shown in the screenshot below, there should be some way to make RH understand which styles should be excluded.
Sreekanth
