We recently upgraded 5 WebHelp projects from RoboHelp 10 to 11. Everything went smoothly except for one project that is displaying a huge amount of broken links. These appear to be for Index words and even Map IDs but the strangest are the ones that appear to be picking up the first few words of a topics. For example: Copying_a_statement.htm#Select_a_statement_and.
Any ideas what may have caused this and how do I go about correcting the problem.
I’d be suspicious of wacky characters hiding in the text that threw RH off its game.
Thanks Jeff, but I knew that the filename was invalid because the # character can't be used in a path. I am basically trying to figure out why this happened and why RoboHelp is picking up Map IDs, first lines of topics and Index words as broken links. More importantly, how do I correct this. When I pull this project up in RoboSource all of the file names for the project's topics are correct and more important ...none of the items displaying under broken links appear anywhere in source control. Am I missing something?
I believe that the hashtag/number sign/pound symbol (#) CAN be used in URLs to reference specific parts of a page. That wasn’t the funky character that I was thinking of.
When you upgraded the project, did you check it out of Source Control first, then let it upgrade?
This particular project was not originally in Robosource, so this was the first time that it was added. Our company policy prohibits us from doing any downloads/updates ourselves so we must rely on tech support to get it right. What funky character were you thinking about? When I double-click on a displayed item under Broken Links, a Topic References dialog displays. If I select the Restore button, I get the following message, "The filename is invalid. The # character cannot be used in a path.
The # character can be used in external CSH calls to topics – RH not allowing it is a different matter.
I’m confused as to how you are operating – if this was an RH10 project outside of source control, then upgrading it and checking it into SC shouldn’t have any impact one way or another. Then when you say when you look at the project in SC, all links are fine?!?! Where are you working on projects? Normally, you would check out the project to your local C:\ drive, do your changes & check it back into SC.
Sorry for the confusion Jeff. This was a RoboHelp 10 project which was on my C drive and had not been put into Source control prior to the upgrade. So I agree, there shouldn't be all of these broken links. The project has now been added to source control. I check out the project to work on it on my C drive. When I finish it, I check it back into RoboSource.
Well, you’ve got two options as far as I can see – restore from backup & upgrade again (making sure that you’re all patched up in RH11) or repair what you’ve got in RH11 already.
A bit late to the party: these broken links were not there in RoboHelp 10?
I would advise to try the following:
1. Make a backup.
2. Remove the CPD from the RH11 project.
3. Copy all the map files (.h), TOC files (.hhk) and index files (.hhp)
into the RH11 project.
4. Reopen the RH11 project.
When upgrading, RoboHelp doesn't touch the map files, TOC and topics. So
it should be fine to copy them from RH10 into the project directly. But
always make a backup as it's better to be safe than sorry.
Kind regards,
Willam
Thanks William! I'll give it a go and let you know how it works.
