Help with realization of a code by "change" event
Avatar
Level 2
The form is developed in Live Cycle 9
There is the following code:
var str = rawValue;
var FIO = str.split (' ');
var a = FIO.length
switch (a) {
case 2:{
        FIO [0] = FIO [0].charAt (0).toUpperCase () + FIO [0].substr (1);
        FIO [1] = FIO [1].charAt (0).toUpperCase () + FIO [1].substr (1);
    rawValue = FIO.join (' ');
          break;
     case 3:{
        FIO [2] = FIO [2].charAt (0).toUpperCase () + FIO [2].substr (1);
                break;
case 4:{
        FIO [3] = FIO [3].charAt (0) + FIO [3].substr (1);
           break;
  default:
    rawValue = str;
This code works on "exit" event (transfers the first symbols of the first three words to the top register, input of all text happens in the bottom register). How to make the given functionality on "change" event. It is necessary that at once at text input in the field the first symbols of the first those words were removed in the top register.
Avatar
Level 10
where does rawValue come from?
you need to specify which object you want to get the value from,
if its the object you are coding in, you must write:  this.rawValue
Avatar
Level 2
  <field name="Strachovatel" y="3.65mm" x="48.65mm" w="125mm" h="10mm">
            <ui>
               <textEdit>
                  <border>
                     <?templateDesigner StyleID aped3?>
                     <edge stroke="lowered"/>
                  </border>
                  <margin/>
               </textEdit>
            </ui>
            <font typeface="Myriad Pro"/>
            <margin topInset="1mm" bottomInset="1mm" leftInset="1mm" rightInset="1mm"/>
            <para vAlign="middle"/>
            <caption reserve="25mm">
               <value>
                  <text>Текстовое поле</text>
               </value>
            </caption>
            <event activity="exit" name="event__exit">
               <script contentType="application/x-javascript">var str = rawValue;
var a = FIO.length
switch (a) {
case 2:{
          break;
     case 3:{
                break;
case 4:{
           break;
  default:
    rawValue = str;
</script>
            </event>
         </field>
Avatar
Level 10
you must indicate which rawValue you want to work with...
using this.rawValue is equivalent to write Strachovatel.rawValue
if you mean another object's rawValue you will have to access to that object before writing rawValue
Avatar
Level 2
I need something like these:
<field name="Strachovatel" y="8.65mm" x="3.65mm" w="170mm" h="10mm">
            <ui>
               <textEdit>
                  <border>
                  </border>
                  <margin/>
               </textEdit>
            </ui>
            <caption reserve="45.707mm">
               <value>
                  <text>toUpperCase</text>
               </value>
            </caption>
            <event activity="change" name="event__change">
if (xfa.event.newText.length &gt;xfa.event.prevText.length &amp;&amp;xfa.event.change.length == 1)
  1. xfa.event.change = xfa.form.topmostSubform.variables.Validation.VerchReg(xfa.event.change);
else
  1. xfa.event.change = "";
</script>
            </event>
         </field>
   <?templateDesigner expand 1?></subform>
      <proto/>
      <desc>
         <text name="version">9.0.0.2.20120627.2.874785</text>
      </desc>
      <?templateDesigner Hyphenation excludeInitialCap:1, excludeAllCaps:1, wordCharCnt:7, remainCharCnt:3, pushCharCnt:3?>
      <variables>
         <script contentType="application/x-javascript" name="Validation">
var first=true;
function VerchReg(newsymbol)
var re = /[А-Яа-я-" "]/;
if (re.test(newsymbol))
if (newsymbol==" ")
  first=true;
  return newsymbol;
if (first)
first=false;
return newsymbol.toUpperCase();
else
return newsymbol;
else
return "";
</script>
         <?templateDesigner expand 1?></variables>
Here only the first character of all words are written in upper case, and we need only the first three words.
Avatar
Level 2
Thu, 20 Mar 2014 09:19:51 -0700 от Robert Gagnon Ranger <forums_noreply@adobe.com>:
>Re: Help with realization of a code by "change" event created by Robert Gagnon Ranger in LiveCycle Forms - View the full discussion
