XML and Escaping a Character in a String
Guest
May 24, 2007 May 24, 2007
I have a small question in regards to XML and escaping a character. I'm reading an XML file and parsing it, then re-creating the XML file with added items. One of the strings has a "-" in it and it spits this out in the XML:  —
Any ideas on how to just read it as text and get it to show as a hyphen?
thanks!
Advanced techniques
3.2K
May 25, 2007 May 25, 2007
I imagine it's reading it fine, you're just not telling it how to output.
An   is a non-breaking space, so that's what's either side of the
hyphen. Your hyphen is displaying as a question mark because it's
probablty not just a simple "-" (ASCII 45), it's probably some extended
character like an m-dash (although not an —) or something like that.
What happens if you tell your browser to output the text as UTF-8 instead
of (whatever it is by default).
Adam
Guest
I still get an error. It comes out a bit odd on text, on the read end of the XML; it looked like a box. It wasn't a plain hyphen, I did try to strip that out before I created the XML and it kept missing it. For the time being, I deleted it so I could test the script.
Hang on... are you getting an *error*, or are you just not seeing what you
want to see? Those are two different things.
How do you know it "looks" like a box? What are you looking at?
What happens if you browse directly to the XML file, rather than reading it
in CF and displaying it?
Is there any indication in the XML file as to which character encoding
scheme it's using?
Adam
May 27, 2007 May 27, 2007
You could use replace() to replace the sequence of characters with the hyphen character.
Guest
Adam,
Have you tried wrapping your code with a CDATA block. For example,
<![CDATA[ problem code here ]]>
Here is the definition from Microsoft's site:
"CDATA sections provide a way to tell the parser that there is no markup in the characters contained by the CDATA section. This makes it much easier to create documents containing sections where markup characters might appear, but where no markup is intended. CDATA sections are commonly used for scripting language content and sample XML and HTML content."
RazorTrak
Sr. Web Applications Architect,
Macromedia Certified ColdFusion MX Advanced Developer
Guest
May 29, 2007 May 29, 2007
I shouldn't say error, my bad. It didn't look correct when I viewed the XML through the browser. It looked like a graphic box. I was trying to figure out why I couldn't just read the XML and write it exactly as I read it into a new XML file and have it look the same when viewing it in the browser. Does that make sense?
>scheme it's using?
The encoding was: iso-8859-1
So, if I copy and paste the picture (from the XML) to here, it comes out like this "–". On the RSS validator, it states that the characters are this: \x96 = which also comes out as a hyphen here. I'm not so sure how to catch this in the future.
Engaged ,
May 30, 2007 May 30, 2007
CDATA is what you need to do....
Are you telling the browser to expect iso-8859-1?
Adam
Guest
May 31, 2007 May 31, 2007
Yes. It seems to work OK with the RSS feed. I thought it wasn't validated. But, it does seem to go through as a hyphen in a Feed Reader.
Documentation
