4 Replies Latest reply on Jun 25, 2016 4:15 AM by scotto71341886
    How can I select multiple files in the Import grid view in LR4?
    ZanderMan Level 1
      So far the only way I have discovered is to laboriously click the checkbox on each image I want to import. It seems that one should be able to select a range with one click (e.g. holding down Shift and then clicking the last image in the range) or by using a context (right-click) menu. No dice. What gives?
        • 1. Re: How can I select multiple files in the Import grid view in LR4?
          quenton8 Level 2
          I think two differeng groups of developers on two different planets designed the Library vs the Import views -- they sure are different!!
          I can answer your question because I had the same question and spent weeks clicking each individually.
          First ignore the checkboxes.  Then use click, ctrl+click, shift+click to select the thumbnails (NOT the Checkboxes, which is why I said to forget them for now!!)
          When you have selected what you want, find one of the selected photos and click its checkbox one way or the other, each click selects or deslects all the "selected" photos.
          • 2. Re: How can I select multiple files in the Import grid view in LR4?
            vaclavRyc
            Thank you Dennis,
            you saved me some nerves
            On MAC use SHIFT + click on thumbnail to selet a row of pictures ...
            • 3. Re: How can I select multiple files in the Import grid view in LR4?
              Bob Somrak Level 6
              Actually the design for the import dialog is pretty ingenious in my opinion.  You can do a "Deselect All" and then use "click  shift-click   and ctrl-click" and then click a check box as you indicate.  You can then repeat this with another group of images without messing with the first selection.  It makes selecting sequences of non-contiguous photos very easy.   You can select 1 thru 10 and then 30 thru 40 without single clicking the second group.
              1 person found this helpful
              • 4. Re: How can I select multiple files in the Import grid view in LR4?
                scotto71341886 Level 1
                Just highlight the photo range you want to import by clicking (highlighting) the first one, then Ctl + Shift (MAC) on the last photo.  All the photos in the range should highlight.  However you'll notice that none of the check boxes are checked, so just go to any image in the range and check the checkbox will will check ALL the boxes in the highlighted range, then click on Import.  I have found this works well for me......good luck and good shooting!
                2 people found this helpful
