5 Replies Latest reply: Mar 25, 2014 7:04 AM by Jeff_Coatsworth RSS
    Which AirHelp option produces less output files?
    ROBOPM Community Member
      Hello All,
      My help topics were created using RH8, and am looking into other web base help solution due to the large amount of files that Web Help currently outputs. For example, Adobe Air in RH8 has the following Output Types:
      • Adobe Air Application,
      • Browser based help,
      • Air Application AND Browser based help, and
      • Help Content.
      My ultimate goal is simply to have a compact output file (e.g., like a CHM file) so my developer can incorporate into his workflow solution (SharePoint 2010) to automatically deploy my web help to not just the central admin server but also all sub-servers. The initial approach of incorporating the help files (currently using RH WebHelp) into the install package did not address that scenario. Unfortunately, for him, he cannot dynamically include all the files into the solution; they must be included one-by-one, which is pain and will cause issues if new files are added later on. Hence, my inquiry to find another web help platform output to reduce the number of files needed to be included in the solution.
      In closing, what do you recommend out of Adobe Air web help solution?
      Thank you all for your time and consideration,
      ~PM
