The word, Search results per page, are cut off on the Search tab. Is there a way to re-size the search panel to make it a bit longer? I'm using RH 10, IE 11.
Probably – you can mess around in the skin file to resize stuff there.
You can do that in the skin file (.skn file). Open it with notepad.
Look for the text cols="220,*" (the first value may be different). Then
replace the 220 with the width of your choice.
This line is present 2 times. In my skin it's on line 13 and 25.
Kind regards,
Willam
Thanks, Jeff and William. I found what I needed in the .skn file and it looks good now. Appreciate your timely responses!
Willam knows the details, I just remember seeing where it was done ;>)
