Can anyone help me with this? Flash has been in use on my mac for a long time, but when I updated to 11 version it never worked right, and kept using older version to play games etc.. and I updated to flash 12, the flash program quits unexpectedly when I open it after downloading it. It prompts to send error report to apple, and will not run flash player. I troubleshoot and have uninstalled all following those steps and still cannot run an installed file of flash. I tried to install earlier versions, 10.3 and others all quit unexpectedly version flash 9 is outdated and cannot be downloaded. I now have NO FLASH PLAYER at all and cannot figure out what is happening ! ANY INSITE would be apprecialted thank you
How to perform a "clean install" of Flash Player in Mac OS X
You may also need to do a COCOA install (OS X's old installer)
Using the FULL Installer: Flash Player 12 Plug-in (Mac OS X)
Save the file and Quit Safari.
Double click that and it will mount on your desktop, and open a window with the installer.
Right click the installer and choose "Show Package Contents"
Go to: Contents/Resources and double click the Adobe Flash Player.pkg file
The installer will open, ask for your Admin password, and it will install.
Hi, thank you so much for the info. I had a problem though, the library did not have the option for flash plugin. instead it had help files so it still doesnt work, and the COCOA i am truely confused and could use some more enlightenment if possible thank u again
</blockquote
Doing the COCOA install isn't that tough.
Download the FULL Installer: Flash Player 12 Plug-in (Mac OS X)
Double click the downloaded file
In Contents/Resources, double click the Adobe Flash Player.pkg file
The installer will open. Follow the instructions.
It'll ask for your Admin password, and it will install.
It's just that easy.
