Show 1 reply
1. Re: Gradient adjustment layer
csuebele Mar 30, 2014 7:22 PM (in response to barpos)The align with layer seems to only work if you have a selection when you create the gradient fill layer, or the gradient fill layer is limited by it's own layer mask. Holding the alt key down and clicking between the gradient fill layer and a lower layer will clip the gradient fill layer to that layer, and the gradient will only show where the underlying had some visibility. Doing this will not change the way the gradient fill layer is applyed by using the align with layer. You would need to make a selection of the underlying layer and apply that selection to the gradient fill layer's mask. Seems like it should work with a clipping mask, but it doesn't seem to do that.
