Wrong assumption. Just because a tool will not work under
Vista, it does not mean its output will not. Think of Word. Word 2
is a really old version and it's quite likely that would have
issues under Vista. If you used it on another PC though to produce
a DOC file, a version of Word compatible with Vista should be
capable or working with that file.
Same thing with webhelp. What could be a potential problem is
if your customers also have Vista as likely that would have IE7 and
that could affect how the webhelp works. Fortunately though the
reports thus far are good. Our own testing did not reveal any
problems.
The decision about webhelp or CHM is dependant on where the
help sits. CHM files should sit on the client PC and webhelp on a
server, although RH6 allows you to apply the Mark of the Web which
enables webhelp to run locally.
