Show 2 replies
1. Re: How do you scan a document from printer to convert to PDF?
CtDave Apr 1, 2014 7:00 PM (in response to Dawneb11)Have the scanner connected to the computer.
Have the scanner software installed.
Check the scanner manufacturer's website for the most recent / updated drivers and install same.
Have Acrobat XI installed.
While Acrobat XI can make use of Windows WIA drivers Acrobat "likes" TWAIN drivers best.
So, if available, have the latest-greatest TWAIN.
Acrobat can communicate with the scanner via the scanner software.
An alternative --
Scan directly to TIFF. Then use Acrobat to create PDF from the TIFF.
Some scanners come with software to output to PDF directly; if present you could use that.
Be well... -
2. Re: How do you scan a document from printer to convert to PDF?
ckendrick Aug 1, 2014 12:28 PM (in response to CtDave)I will try this thank you.
