Locked
Video Usage
Guest
Mar 27, 2014 Mar 27, 2014
IS there anyway to determine how many times a video has been access in AMS 5? I have looked at the apache log, but a streamed video appears many time for just one playing. Thanks for any help.
891
You can use the server-side scripting API  to increment a counter each time a certain resource is accessed.
http://help.adobe.com/en_US/adobemediaserver/ssaslr/WS5b3ccc516d4fbf351e63e3d11a11aff5ba-7f8bSSASLR....
Or
http://help.adobe.com/en_US/adobemediaserver/adminapi/WSa4cb07693d12388431df580a12a34991ebc-8000.2.3...
Personally, I'd probably not try to handle this through AMS. I'd get and save the number of views to a given resource to a separate database.
Guest
Mar 31, 2014 Mar 31, 2014
Thanks for your response, but I'm really new at AMS. I can develope in ASP.Net. With that said, can you elaborate in a little more detail how to accomplish this. Perhaps the method name to use or a sample code snippet would be greatly.
Sure. It's just javascript.
If you only have one video in your application:
var accessCount=0;
application.onConnect = function (client){
     accessCount++;
Or if you want to track a specific video:
var accessCount;
application.onConnect = function (client,resource){
     accessCount[resource]++;
where "resource" is a string variable that you pass when the client application connects to the server.
And if you want to retrieve this number from your client:
Client.prototype.getMetrics = function(resource){
          return accessCount[resource];
Or you could even use the File class and write to an exteral file if you wanted.
Guest
Apr 01, 2014 Apr 01, 2014
Perhaps I'm missing something. My videos are mainly packaged as manifest files and embeded as html objects in our training applicationa, internet/intrannet, etc...
Are you saying the javascript should be added to the page that host the html object?
I am not saying that the javascript should be added to the page that hosts the html object.
I am assuming that your AMS application works like mine, which may be a false assumption.
But my folders  on the server are laid out like this:
Adobe Media Server 5\Applications\[name of application]\[name of application].asc
The javascript is in the .asc file.
This is similar to this
http://help.adobe.com/en_US/adobemediaserver/devguide/WS5b3ccc516d4fbf351e63e3d11a0773d56e-7ffdDev.2...
When clients connect to your server, they hit the .asc file first. This is where you can accept, reject, or count connections.
Adobe Employee ,
if you are looking for a solution to rtmp streams then Jim's answer is one of the ways...You can also inspect access log for AMS(not apache) to find put rmtp streams/clients playing a stream.
Howeever if you want to look for statistics for HDS/HLS streaming(which happens through Apache and its modules) then you will have to look at Apache logs(access logs for Apache)
Guest
Most of my videos are HDS. I looked at the Apache log, but need a little help in parsing the log for multi bit rate streaming. One playing of a video generates many, many entries into the log. For example:
124......... - - [31/Mar/2014:02:29:22 -0400] "GET /hds-vod/Vogtle_800.f4v.f4m HTTP/1.1" 200 2025
124......... - - [31/Mar/2014:02:29:22 -0400] "GET /hds-vod/Vogtle_1500.f4v.f4m HTTP/1.1" 200 2028
124......... - - [31/Mar/2014:02:29:45 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag1 HTTP/1.1" 200 97018
124......... - - [31/Mar/2014:02:29:46 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag2 HTTP/1.1" 200 161506
124......... - - [31/Mar/2014:02:29:49 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag3 HTTP/1.1" 200 1040005
124......... - - [31/Mar/2014:02:29:55 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag4 HTTP/1.1" 200 834187
124......... - - [31/Mar/2014:02:30:01 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag5 HTTP/1.1" 200 366308
124......... - - [31/Mar/2014:02:30:03 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag6 HTTP/1.1" 200 401652
124......... - - [31/Mar/2014:02:30:06 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag7 HTTP/1.1" 200 221894
124......... - - [31/Mar/2014:02:30:12 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag8 HTTP/1.1" 200 371067
124......... - - [31/Mar/2014:02:30:14 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag9 HTTP/1.1" 200 506740
124......... - - [31/Mar/2014:02:30:18 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag10 HTTP/1.1" 200 538230
124......... - - [31/Mar/2014:02:30:22 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag11 HTTP/1.1" 200 449507
124......... - - [31/Mar/2014:02:30:28 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag12 HTTP/1.1" 200 321969
124......... - - [31/Mar/2014:02:30:30 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag13 HTTP/1.1" 200 429534
124......... - - [31/Mar/2014:02:30:36 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag14 HTTP/1.1" 200 415903
124......... - - [31/Mar/2014:02:30:38 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag15 HTTP/1.1" 200 533145
124......... - - [31/Mar/2014:02:30:44 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag16 HTTP/1.1" 200 336615
124......... - - [31/Mar/2014:02:30:46 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag17 HTTP/1.1" 200 519305
124......... - - [31/Mar/2014:02:30:50 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag18 HTTP/1.1" 200 533103
124......... - - [31/Mar/2014:02:30:53 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag19 HTTP/1.1" 200 658543
124......... - - [31/Mar/2014:02:30:59 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag20 HTTP/1.1" 200 894845
124......... - - [31/Mar/2014:02:31:06 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag21 HTTP/1.1" 200 883363
124......... - - [31/Mar/2014:02:31:11 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag22 HTTP/1.1" 200 363477
124......... - - [31/Mar/2014:02:31:16 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag23 HTTP/1.1" 200 175650
124......... - - [31/Mar/2014:02:31:17 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag24 HTTP/1.1" 200 528201
124......... - - [31/Mar/2014:02:31:22 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag25 HTTP/1.1" 200 454561
124......... - - [31/Mar/2014:02:31:25 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag26 HTTP/1.1" 200 705040
124......... - - [31/Mar/2014:02:31:31 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag27 HTTP/1.1" 200 367943
124......... - - [31/Mar/2014:02:31:34 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag28 HTTP/1.1" 200 139240
124......... - - [31/Mar/2014:02:31:37 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag29 HTTP/1.1" 200 773752
How can get only the distinct viewing of the video?
Adobe Employee ,
Apr 02, 2014 Apr 02, 2014
The following line indicates a request for manifest file( .f4m in this case)...There is a single manifest file generated per stream..so this request should tell you the video files being requested.
BTW on side note, the industry practice is to put a vranish in front of Apache web server and log/account all requests on varnish itself.
