6 Replies Latest reply on Sep 14, 2007 3:29 PM by Newsgroup_User
    CS3 can't download the htaccess file
    Mike52179 Level 1
      I recently upgraded to DW CS3 and noticed that I can't download a .htaccess file. Even if I create the file manually in my local directory, then I click GET, DW comes back with an error saying the file doesn't exist on the local site.
      I even uploaded from DW then immediately initiated a GET and still received the error
      This didn't happen on previous versions of DW, it's new with CS3
      Anyone know of a fix?
        • 1. Re: CS3 can't download the htaccess file
          Level 7
          On Fri, 14 Sep 2007 13:59:38 +0000 (UTC), "Mike52179"
          >site.
          >the error
          I have Dw CS3 and have no problems putting or getting .htaccess.
          The only issue with it - is Dw doen't load the file to edit it if you
          doublle click.
          ~Malcolm N....
          • 2. Re: CS3 can't download the htaccess file
            Level 7
            >site.
            >the error
            .htaccess probably cannot exist on your computer since it is an
            liiegal filename. I edit mine in UltraEdit, but you could also rename,
            download, edit, upload, rename.
            • 3. Re: CS3 can't download the htaccess file
              Level 7
              > liiegal filename.
              In what operating system using what filesystem? Clearly not on most
              *nixes; I just opened, edited and saved a file named .htaccess in XP Pro
              with NTFS.
              Joe Makowiec
              http://makowiec.net/
              Email: http://makowiec.net/contact.php
              • 4. Re: CS3 can't download the htaccess file
                RustyCT Level 1
                If you're using a Mac, files cannot start with a period. I change the name of file on the server, edit the file, then change name back. Don't know if Windows can use a period to start file names.
                Hope the workaround helps,
                Russ
                • 5. Re: CS3 can't download the htaccess file
                  Level 7
                  On Fri, 14 Sep 2007 17:14:17 +0000 (UTC), Joe Makowiec
                  >> liiegal filename.
                  >with NTFS.
                  Clearly most people do not use *nix. :) I do on two computers, but
                  haven't touched those computers in a month.
                  I didn't realize XP was okay with that; I've worked around it for
                  long, it comes automatically.
                  • 6. Re: CS3 can't download the htaccess file
                    Level 7
                    On Fri, 14 Sep 2007 16:19:37 -0500, Mister Mustard <mustard@hotdog.com>
                    On my Win2k machine with DW8, I added .htaccess to the open in code view
                    list in the preferences. When I double-click an .htaccess file, it opens
                    in code view. I can open, edit and upload just fine.
