I received your distribution then tried MSI & EXE packages to install it in a large amount of computers in my company. Tested in a computer then the install completed shows in control panel the right version 12.0.0.77.
When testing to the web site http://helpx.adobe.com/flash-player.html I'm informed that Flash is not installed in my computer.
Issue is that I cannot open a file in acrobat using Flash technology. File is issued by IATA and containing TACT information for 2014.
On the same computer, if I install Flash Player from Adobe web site (downlod center) this fix my issue. Platform is Windows 7 SP1 in French IE9
Thanks in advance
Yves
What files do you have in
Can you post the contents of the FlashInstall.log files in the above folders? (Not everything, just the last install.)
Hi Pat
As I’m not having to many machines to test I had to re-image the computer issued.
Please see attached the log file.
I can see with a new install based on the same image (I use lmagex to clone my machines) the issue is now fixed when installing the same MSI distribution file.
Only point is the error message I can identify on top install process (Log file). I don’t know if there is normal but Flash is detected and able to open web sites with Flash technology.
2014-4-1+14-45-28.722 1226 1062
=O====== M/12.0.0.77 2014-04-01+14-45-26.912 ========
0000 00000010 "C:\windows\TEMP\InstallAX_12_0_0_77.exe" -install -msi
0001 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0002 00000020 C:\windows\system32\FlashPlayerCPLApp.cpl
0003 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0004 00000013 C:\windows\system32\Macromed\Flash\Flash32_12_0_0_77.ocx
0005 00000015 C:\windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
0006 00000016 C:\windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
0007 00000023 C:\windows\system32\Macromed\Flash\activex.vch
0008 00000019 C:\windows\system32\FlashPlayerCPLApp.cpl
0009 00001024 C:\windows\system32\FlashPlayerCPLApp.cpl 183
0010 00001024 C:\windows\system32\FlashPlayerApp.exe 183
0011 00000021 C:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0014 00001024 C:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/12.0.0.77 2014-04-01+14-45-32.014 ========
Thanks for your mail
Envoyé : vendredi 4 avril 2014 11:38
À : Yves Palmas
Objet : Issue installing distribution from Adobe Flash Player 120.0.77
Re: Issue installing distribution from Adobe Flash Player 120.0.77
created by Pat Willener<http://forums.adobe.com/people/pwillener> in Installing Flash Player - View the full discussion<http://forums.adobe.com/message/6270912#6270912
I see that there is an error for C:\windows\system32\FlashPlayerCPLApp.cpl and C:\windows\system32\FlashPlayerApp.exe
You need to perform a clean install on computers showing these symptoms: http://forums.adobe.com/thread/928315
