4 Replies Latest reply on Jun 6, 2007 9:00 AM by insuractive
    Populate 2 Columns from Query
    IraMSN Level 1
      I have a query that selects all performers in the current week. There are many rooms that a performer can be scheduled in and sometimes there is no performer scheduled in a particular room or at a particular time.
      The query looks like this:
      <cfquery datasource="#application.ds#" name="qrySchedule" maxrows="1">
      select *
      from SHOW_SCHEDULE
      WHERE calend >= #createodbcdate(now())#
      order by calend asc
      </cfquery>
      The table row has about 20 fields ie; room1earlyperformer1, room1lateperformer1, room1earlyperformer2, room1lateperformer2, room2earlyperformer1, room2lateperformer1, room2earlyperformer2, room2lateperformer2 ...etc.
      I would like to be able to display this query output in a 2 column table while not leaving any table cells blank if there is no performer scheduled in a particular room at a particluar time.
      Can someone please help with a code example? Thank you!
        • 1. Re: Populate 2 Columns from Query
          Dan Bracuk Level 5
          Normalize your database and you won't have problems like this.
          • 2. Re: Populate 2 Columns from Query
            insuractive Level 3
            Just out of curiousity, if not blank, what would you like to see in the table cell when there is no performer scheduled?
            • 3. Re: Populate 2 Columns from Query
              IraMSN Level 1
              quote:
              Michael,
              If the performer record is empty, just skip it and populate the cell with the next record that contains data.
              • 4. Re: Populate 2 Columns from Query
                insuractive Level 3
                Its pretty unclear from your description what exactly your 2 column table consists of and how it relates to your 20+ fields. So are you trying to do something like this:
                Room: Performer:
                1 Joe (Early)
                1 Pete (Late)
                2 Simon (Early)
                If so, I think you really do need to follow Dan's advice and normalize your database. Instead of 1 table with 20+ fields, you probably should have 3 tables
                Table 1: Rooms
                Room ID
                Table 2: Performers
                Performer ID
                Performer Name
                Table 3: Schedule
                Schedule ID
                Room ID
                Performer ID
                Performer Order
                This structure would give you a lot more flexibility over how to control and retrieve your data.
